Old 06-17-2016, 02:13 AM
backn65's Avatar
backn65 backn65 is offline
Default where does this part fit?
This part came off my old 326 and i don't recall where it was on the engine or what it does?
seems like it is related to the oil filter housing/sending unit.
Old 06-17-2016, 05:32 AM
Jeff Hamlin's Avatar
Question
Looks like a Heat Gate Stop;
Old 06-18-2016, 01:37 AM
backn65's Avatar
thanks jeff, i thought it had same bolt pattern as filter base, forgot about the heat riser, have had repro headers for some time.
i have another part that for the life of me i can't figure out where it mounted. it is a piece of sheetmetal that mounted around the frame/wheel well area. i will look for the piece and then post a pick,it was removed when the 400 went in.
Old 06-18-2016, 06:27 AM
Glad to help.
Wild Guess on the sheet metal pc...
Linkage Guard/Shield??
Old 06-19-2016, 11:45 AM
Tempest's Avatar
Tempest Tempest is offline
Jeff,
You have the best pics for everything.
Thank you for contributing to this forum, your knowledge and pics are much appreciated.
