Sealing emblems
I removed the gills on my 2+2 to buff and polish. Cleaning up the speed nuts I found they were packed with something. At first I thought it was just dirt. But the way it came back out of them it appeared to be some type of sealer.
When in installing emblems and such do we use an o-ring on the stud and then the speed nut or some type sealer to seal the penetrations? |
Yep it's basically like butyl tape (the black sticky sh!t you can buy on a roll to re-seal your windshield). It's water proof and doesn't harden.
I have some putty we use to seal fiber optic cables where it leaves the conduit. It does not harden and it keeps water out even when submerged. It's non petroleum based also.
Sealing emblems
I used 3M black strip caulk on mine.
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
Try Ace Hardware Plumber's Putty Roll. Item no: 4008652 | 082901001980. http://www.acehardware.com/product/i...631266.2631356
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs 1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold |
Mortite is a trade name for same product. Used to be used to seal windows. Came in a tape roll similar to pictured, but was only about 1/8-1/4" wide. Not sure if still made or not.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
This is the stuff. It's great for many uses, and it never dries out or gets hard.
Duct seal! Awesome stuff! Or gorilla snot. Or elephant snot. Lol. Thinking about using it behind my roof rail weatherstrip. Strip caulk will also do the trick i think.
It's hard to soar like an eagle, when you're surrounded by turkeys! My wife says she'd llike my car a lot more if it wasn't mine. 64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam. |
Hey Red were they the longer white ones? Plastic with a small nut inside.......same as the lower body trim nuts?
No they were the regular stamped metal speed nuts.
Were yours replaced at one time? I'm sure my trim was never removed.
These are about 3/4 inch long white plastic with the nut inside. They are very brittle, some broke apart as I removed them and I found the smaller nut inside. I'll take some pics and post them up if you like.......... |
Yes mine had been removed at some point and time when the car was repainted. I will say though that there was decades of gook in them. I have a source that may know. Will let you know.
You are correct. Tan colored plastic nuts. Looks like I need to go shopping
Do you have a source for those plastic nuts?
no I don't..........
