Old 10-02-2016, 01:20 AM
c.w. fields c.w. fields is offline
Default 75 Grand Am/Grand Prix Fiber Optic Bulb
My fiber optic works to light up the ash tray and selector lever on console however the light is very dim. I would like to install a LED bulb in hopes that it makes both brighter. Can anyone tell me where the bulb is located in the dash and how to get to it. Thanks
Old 10-02-2016, 02:43 AM
The fiber optic is plugged into a dash bulb that has a clip like item that holds the fiberoptic tube up against the bulb, & then again goes to the other items & plugs in to a fitting there to. If you look the optic cable is up against the bulb in the cluster closest to the ash tray
