Rear view mirror
Inside. Would it work/be safe to use super glue to stick it to the windshield ?
Or should I buy the kit?
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I never tried super glue. I always just get the mirror adhesive kit, since it's only about $5 at most.
Steve F. |
Use the correct adhesive, superglue will fog up and make a real mess and other reasons it isn't the glue of choice.
Your local glass replacement shop can do it for you, I know a kid in Spain that needed the metal PC for his '80 T/A, so I stopped in Henderson glass, here in the D, the guy gave it to me for him, but they also have the glue.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes pause pause F ire B irds 🇮🇱 |
Bought the kit at Autozone. Thanks for the info, OGR
The glue used for the bracket is designed to withstand the UV rays. Super glue is not.
Butch |
Take a small piece of scotch rite and slightly scrub the glass where you are placing the tab, it can help.
Super glue will soak in & delam the glass & then you'll be buying a new windshield. Yes glass is porous.
If you get a new windshield, it it marked where the metal PC goes?
New windshield normally comes with a rear view mirror mount already glued to it.
Steve F. |
