Old 10-28-2016, 09:38 AM
mgoblue mgoblue is offline
Default Rear Axle Seal
When installing new rear axle seals, do you coat the rubber with grease? If so, what do you use? Just a general grease, white lithium, etc?
Old 10-28-2016, 10:01 AM
694.1 694.1 is offline
Yes. Either.
Just be careful not to drag the axle on the seal while installing.
Old 10-28-2016, 12:28 PM
Any oil or grease. You just dont want it "dry". Be careful installing. If you are too rough, you could knock the spring off the seal. Nice and easy and keep the weight of the axle off the seal.
Bill Nye.
Old 10-28-2016, 02:35 PM
Good advice, thank you both.
