Pro Touring Pontiacs check in
I thought it would be a good idea for the small Pro-Touring Pontiac community on this board to get together in a thread. Post up some pics, a description of your car and maybe some events you've done or are planning to do or whatever it is you do with your pro-touring pontiac. Weather its SCCA, Goodguys, Optima USCA, daily driving, canyon carving etc....
Ill go first... 1967 GTO, SC&C suspension, new 434" Pontiac mill is getting built by PaulK, Richmond 5 speed, 9", C6 brakes, FiTech EFI. Iv'e done Goodguys autoX, Street Machine nationals auto X, Waumandee hill climb, Midwest musclecar Challenge and this year i'm adding Optima Search for the ultimate street car at Road America.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
My car is still in the process of becoming a “pro touring” car. Currently I am running 275/40/17 on 17x9 wheels and have:
front suspension: 1 3/8” front sway bar with poly bushings H-O Racing lower springs Koni shocks Rear is: Hotchkis upper and lower boxed control arms 7/8” rear sway bar Bilstein shocks Eibach sport springs Bought but not yet installed: UMI front tubular A arms Viking coilovers Fast ratio steering box Still yet to purchase: larger disk brakes
1972 LeMans 461 stroker 10.3:1 Edelbrock D ports Scorpion 1.5 rockers Comp Cams "Stump Puller" roller Holley Ultra Street Avenger 770 Ram Air III exhaust manifolds 2.5" pipes Dynomax VT w/crossover Edelbrock Performer RPM TH350 2.78:1 10 bolt |
Nick, what R&P ratio are you running? That's a 4+1 Richmond and not the OD model, right?
___________________________________ "Objects in mirror are closer than they appear" |
In progress here as well. All stock drivetrain for now. 455 in the works along with plans for hydroboost, wilwoods, efi and 2004r among other things.
We like to drive! Pic below on 2016 Hot Rod Power Tour. |
2.75 ebay Ford gears in a Moser 9". It is the old 1:1 5th gear Richmond
UMI Front Upper and Lower Tubular Control arms w/ Tall upper Ball Joints WS6 Front Sway Bar Boxed Rear Upper and Lower Control Arm( forgot the brand ) UMI Extreme Rear Sway Bar UMI Frame Braces Hotchkis Springs Bilstein Shocks Stock Power Steering converted to Fast Ratio Wilwood Master w/ 9" Booster Front Brakes converted to OEM Style Single Piston Calipers My love for RWL tires and just not finding a 17" rim that excites me has made it difficult for me to give up on the 15" rims...... except for 1 style The Weld RT-S I just cant afford them.... yet... Once I have the big wheels...... Big Brakes and Hydroboost will follow..
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
I finally have something to contribute! 78 TA with a mild 400, factory crank, forged rods and pistons, Lunati 262 cam with TH350 and 3.23 gears running through an Eaton trutrac going to the ground on 18 x 9.5 TSW wheels and 275/40/18 rubber, square. I have 750# springs in front and Viking DA shocks on all 4 corners with the factory leafs and sway bar in the back.
I have driven in several Optima Street Car events, SCCA Pro-Solo and Cam Challenges, Good guys events- only on Sundays tho. and local events through the different clubs in the DFW area. Over the winter I have been making a bunch of changes. I fabricated a pan hard bar for the rear and G brace for the front, added C5 disc brakes front and back, Edelbrock heads and Dougs headers and updated the booster and MC to 4th gen set up to help keep up with the new brakes. |
I don't have any cool action shots like ya'll do but here is my Pro-Touring Lite car. Due to some engine issues, I have not been able to keep up with the Jones's in the pro-touring scene but hopefully that will all be behind me with the new 434 that Paul K is helping me with. Anyway, nothing real fancy. 17X8 American Racing wheels, Third gen 1LE brakes and steering box, Rancho bars, Koni shocks, Hotchkis springs, GW control arm bushings and SFC. Outside of the 434 going in, next up are LS1 rear discs and C4 ZR1 fronts:
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. Last edited by Formula8; 02-15-2017 at 01:15 PM. |
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
Here are a couple pictures of my 70 T/A. This was my first autocross in 2015 and these were taken when it was still sitting on it's stock coils and leafs and stock brakes.
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15. 1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-( 1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-( |
Very Nice! Still old school but a great modern stance and the meats in the back look MEAN!
These are KILLER cars fellas. This is exactly why I started this thread. Pro Touring builds unite! Excellent stuff guys. Keep them coming!
Didn't get to finish my post last night.
After taking the T/A to it's first autocross in 15' I realized how much fun it can be, but also how much help the car needed. Each run I would lose brakes mid way and the 45 year old suspension gave no feedback. Last year was the start of the improvements! Put hotchkis coils and leafs on it, konis on all four corners. New subframe connectors with solid mounts. For brakes it now have Wilwood 13" 6 pistons up from and right stuff discs on the rear. Modern MC and booster to go with that. After those changes and a few others the car is totally different, in a good way I am by nowhere near done as I am still running my numbers matching engine, which I will pull as I don't want to hurt it. Build is similar to Nicks. Anyways, happy to see these awesome Pontiacs out, there isn't much thats more fun then throwing these cars around the track. I'll try and put up a video later on me running on a road course: ) Sent from my SM-J320W8 using Tapatalk
In progress, hope to be driving this summer.
406, Eagle rods, KB pistons, Lunati Voodo, Eddy top end, MSD & FI Tech, RA exhaust because it sit's so low. Legend 5 speed with McLeod twin disc. UMI stage V with DA Viking coilovers, IROC box, Signature big disc on all corners. US Mags 18X8 & 18X9 245 & 275 40's. |
Yes, March serpetine. The kit comes with an eddy waterpump, but im using a flowkooler. Im very impressed with the March quality, well worth the cost. As a bonus, the sales rep Doug had the a/c compressor manifold powdercoated black for me, thought it would look better and he was right.
I can take some more pics, will have to resize them later. OBTW, your project has served as an inspiration for me. My numbers matching stuff is in the shed too |
