Old 03-03-2017, 02:05 AM
michael j michael j is offline
Default Spot weld
I have a 74 trans am and I am wondering why is nut on the upper a arm shaft
spot welded to the shaft. I think I read something about this on these forums but can't find it. Thanks
Old 03-03-2017, 09:53 AM
77 Canamman's Avatar
This was touched upon in NJSteve's thread on his 1975 Firebird.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 03-03-2017, 06:02 PM
njsteve's Avatar
njsteve njsteve is offline
Here you go: http://forums.maxperformanceinc.com/...664082&page=16
Old 03-04-2017, 01:59 AM
Gentlemen thank you all for the service bulletin, pictures and instructions. Like always, this site is tops for information.
Old 03-04-2017, 11:46 AM
importsmasher's Avatar
importsmasher importsmasher is offline
I had a 74 GP years ago that had welded nuts. I went to replace the bushings, having no idea the nuts were welded (the control arms were caked with grease). I used a large breaker bar and was able to break the nuts loose, but no matter how much I turned them they wouldn't come off. That's when I discovered the spot welds. I then cut the shaft and replaced them. If I was doing the job now, I would have cleaned the parts, and noticed the welds lol.
I always wondered who would have welded them and why.....now I know.
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 03-04-2017, 12:57 PM
njsteve's Avatar
I love learning new trivia about these old birds.
BTW, I bought the new AC Delco bushings and center bar with the offset to allow for more camber adjustment. I installed them with the offset facing toward the wheels and brought it to the alignment shop. The car did not need a single adjustment shim! It was exactly in spec with just the new offset bars alone!
Old 06-13-2022, 10:19 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Digging up an old thread....
Both upper A arms have a spotweld on one end of the shafts on my 74 TA. I have the A arms off the car to replace bushings, ball joints etc.
I see mention in the 75 service bulletin (see above) of a 'procedure' on page 3-25 of the 75 Service Manual - does anyone know what that procedure is?
What is the best approach here - or should I just buy new shafts and replace them?
TIA!
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
Thread Tools
Display Modes
