Old 04-22-2017, 10:36 AM
steve's Avatar
steve steve is offline
Default pics of pedal mounted kick down switch in 2nd gen
doing a 'custom' install of a TH400 kick down switch in my 81 this week. looking for a nice clean pic of what the finished install should look like for the switch that is actuated by the gas pedal under the dash in a second gen F-Body.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 04-22-2017, 11:33 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Look at 81 Z28s as they had a cowl hood flap throttle pedal switch activated. I think I have one in the garage I'll look for.
Skip Fix
Old 04-22-2017, 07:43 PM
78w72 78w72 is offline
not sure if this shows what you need, it's pretty tight under there for side views.
Old 04-22-2017, 09:24 PM
mtnbktrek mtnbktrek is offline
That's for the switch pitch 400 right? I picked up the SP th400 and it came with that switch I think. Was going to put it in my lemans but tuff to find a converter
1968 LeMans Convertible - 462 w hydo roller comp cam forged flat tops- 6x-4 heads- performer intake - 800 cfm QJ- edelbrock 110 gph mech fuel pump- 4 row copper rad- followed by a Th400 w/2300rpm stall then a nodular 10 bolt posi w 3:90 gears ( need 3:55 bad
Old 04-22-2017, 11:23 PM
no, standard th400 used an electric kick down switch.
Old 04-23-2017, 06:33 AM
steve's Avatar
thanks thats what I'm looking for. my accelerator bracket is not drilled for the holes. I'll have to guess the exact location.
Old 04-23-2017, 03:06 PM
Skip Fix's Avatar
Here you go
ID:	452789   Click image for larger version
Skip Fix
Old 04-23-2017, 08:24 PM
steve's Avatar
Originally Posted by Skip Fix View Post
Here you go
So this is for a turbo hood ?
Old 04-23-2017, 08:40 PM
Camaro. Z28 Air Induction. 1980-81
Bill Nye.
Old 04-23-2017, 10:42 PM
NeighborsComplaint's Avatar
You may have a manual trans gas pedal bracket in the car if it isn't drilled. The A bodies are that way. Manual trans bracket was different than auto.
There's one on ebay right now. http://www.ebay.com/itm/70-81-Camaro...FYzwsS&vxp=mtr
I have a spare GM NOS switch. If you're interested, PM me.
Old 04-24-2017, 03:53 PM
Skip Fix's Avatar
Yep the 81 Camaros had a small cowl hood scoop that was electronically actuated . I never knew that until I parted one out to turn my plain Camaro into a Z28-that is gettign the 500" IA motor. In fact pulled the 383 SBC out this weekend to get ready fro the swap.
Skip Fix
Old 04-24-2017, 03:58 PM
Mace1971's Avatar
Mace1971 Mace1971 is offline
That's a ginormous mount compared to the early 70's one. Check Ames, pretty sure the have the earlier small mount.
-- Kevin
1971 Trans Am, White/Blue
455 YC Block with Edelbrock Performer RPM Aluminum Heads, 10-10.5 estimated CR, E-Performer Plus cam (soon to be 041 + Rhoads), Comp Cams 1.65:1 roller tip rockers, E-Performer Aluminum Intake (soon to be topped by a FiTech EFI), TRW forged pistons, Hedman Husler Headers, 3" dual exhaust with Flow Master mufflers.
Old 04-24-2017, 06:31 PM
Skip Fix's Avatar
The mount is just on the side of a normal pedal bracket.
Skip Fix
