Has anybody done a 10dn to 10si conversion on their 65 grand prix. Mine has the ammeter and 2 wire voltage regulator. Not sure how to do this conversion with my setup. Thanks
If I recall correctly all you need to do is attach the main wire to back of 10SI as normal, then add a wire jumper from that to #2 terminal of alternator's plug-in connector. You can also wire a charge light if needed from #1. Unplug connector at the old voltage regulator and wrap it up for protection.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool |
The current shunt for the meter is a tap in the wiring where it runs along the intake. The ammeter won't care what alternator you use, it will work as normal.
65 Bonneville Brougham 4DHT 65 Grand Prix 2DHT......now parts 65 Catalina 2+2 2DHT 65 Catalina Safari 4DSW |
I was wondering about this myself. So with our cars only having 2 wires at the regulator, we simply unplug it? No jumper there like on the 3 wire ones?
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
Right, nothing else (but the jumper at alternator output to Term #2) is needed. The field wire from old regulator is no longer required...and the other wire to regulator was simply ignition-switched power to it. Like LAS noted, the ammeter shunt already i nthe wiring harness delivers the charging current to battery.
Where is the shunt in the harness located?
They just use the wire itself as the shunt, it's not a separate part.
