Old 06-23-2017, 07:11 AM
Hooter's Avatar
Hooter Hooter is offline
Default 565ci to 520ci hp/tq difference
Old motor in my street car 65 was a 4.75 stroke 565 pump gas motor. Made 820 hp at 6400 before and can't recall the torque(quite a bit). Now, destroked with a Molnar 4.375 crank, same length 6.7 rods(pin is now out of the oil ring) and Diamond pistons. Compression will remain the same at 11.5(had to use a thicker head gaskets with the previous increased stroke so better quench now). Old motor had low tension rings and a vacuum pump. New motor has standard style rings an no vacuum pump. Here's a few quick particulars:
KRE block at 4.35 bore
CV1 out of box heads and low rise intake
1050 BLP dominator
Comp 4/7 swap cam. 276/284 on a 113. 700/726 lift after lash
Comp roller rockers with stud girdle
Same POS Heddman 2" headers with flat 3.5" collector
Essentially it's the exact same motor minus the stroke and low tension rings/vac pump. Destroked due to blowing a roller lifter on Drag Week 2 years ago and putting trash all through the motor. Pistons pretty scuffed up and decided to make the motor more street friendly.
Going on the dyno tomorrow. Curious what you guys think it will make compared to before..
67 Bonneville ragtop
Old 06-23-2017, 07:37 AM
Probably need higher RPM peak.
775 HP
Old 06-23-2017, 08:23 AM
Half-Inch Stud's Avatar
Curious what fuek was/will be used, and the difference in timing. Think HP will be same but at diff RPM or 1% lower (due to rings).
Old 06-23-2017, 08:28 AM
firechickenman's Avatar
firechickenman firechickenman is online now
I think it will lose some HP but not much and will make it at higher RPM. It will lose more torque. Good luck!
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 06-23-2017, 08:54 AM
mgarblik mgarblik is offline
I think you will give up about 30-35 lbs. torque and have a slightly narrower torque curve. If you can make HP at 800-1000 RPM higher, peak HP will be near the same. Have fun on the dyno.
Old 06-23-2017, 09:49 AM
Hooter's Avatar
Fuel will be 93 octane pump gas. Same as before. Kinda figure will spin it to 7,000 or so this go around depending on what it likes. Previous timing was at 28 degrees.
Old 06-23-2017, 09:58 AM
steve25 steve25 is online now
X2 with reply number 5.
Old 06-23-2017, 10:02 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Idk....but good luck!
Go fast, see Elvis!
Old 06-23-2017, 10:15 AM
slowbird's Avatar
slowbird slowbird is offline
Same dyno facility correct?
Old 06-23-2017, 10:38 AM
John Langer's Avatar
John Langer John Langer is offline
When I went from 525 to 565 I picked up only around 45hp peak but like 70 average in the power band and gobs of torque. Going in reverse expect similar results. On my change I just changed rods and crank. Everything else was identical.
Old 06-23-2017, 12:55 PM
Hooter's Avatar
Yup
Old 06-23-2017, 03:15 PM
slowbird's Avatar
Im curious if your peak rpm changed much?
Old 06-23-2017, 03:19 PM
Dave M's Avatar
Dave M Dave M is offline
Good luck Hooter!!
Old 06-23-2017, 03:25 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Similar HP more rpm. Good luck!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 06-23-2017, 04:48 PM
That's a good data point.
Old 06-23-2017, 05:43 PM
Probird's Avatar
Probird Probird is offline
I'm going to say it will lose about 50hp. A few from less ci and 25 or so from losing the low tension rings and vacuum pump. So my guess is 770hp.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 06-23-2017, 06:24 PM
Hooter's Avatar
I'll be happy if it hits 775. The car is getting a cage so I can legally go 9's this year. Hoping I'll have enough motor to do that with the downsizing lol.
Old 06-23-2017, 08:10 PM
BADDTA's Avatar
BADDTA BADDTA is offline
1050 BLP dominator
Not enough to keep up with the little stock block.
Brian
Boobs & bacon
Old 06-23-2017, 08:45 PM
Hooter's Avatar
Brian
My first call out... that is a bad little stock block sob. Guess I shouldn't of sold you guys the block lol
Old 06-24-2017, 12:31 AM
Exact same rpm. Now going from 477 to 525 was a around 6-800 difference in peak rpm
