Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Ram Air V heads for sale. Original GM castings. Pressure checked and maged. Aftermarket titanium valves, sprigs, keepers. Comes with pushrod guides and I believe valve guides. Have to dig the parts out. Does have a few air foils, but not a complete set. Lets discuss....
10K mornellas13@gmail.com
Pictures attached.
more
Intake is not included.
Mike,I have foils if you or the new owner needs them.Tom
Got it,
I was thinking the same.
Any ram air v intakes for sale too?
How many cc's are the heads' chambers? |
Tom has spoken for the Dual Quad intake. I don't have a single 4 barrel intake, but I believe Tom may be able to assist. I sold my last NOS 4 barrel intake 3 years ago.I may have other important hardware for the factory intake in the garage though.
These heads have not been decked so they should be 78 CC's.
are they 44 castings or DS # or nothing?? I also am looking for a 400 intake.
the casting area is blank and is the only set I've had like this. I've had Developmental and 44 castings, but this is the only set I've had that are blank
Interested in the heat riser and oil drippers if you have. Also interested in the 2x4 Intake behind Tom. Thanks KC
Hi KC -
The heat riser that you see in one of the shots is a hand made item and not an original. I have more then a few pairs made. I can throw them in with the sale. Just talked to Tom and it sounds like he is going through with the purchase of my intake. I'm sure he'll have something available for you shortly once he gets mine. I don't have any oil droppers for this engine. Let me know soon if you're serious about the heads as I have a few bites already. thanks mike
Mike, I am not interested in the heads, interested in a heat riser if you have a spare to sell, pulley`s and a square coil if available. What intake hardware were you referring to in another post? Thanks Ken.
I can sell you a set of heat risers. I think I may have two sets left.
I've built a RA V factory stock top end to fine detail and have extra parts if interested. Things like bolts, brackets, washers, etc... Contact me here if interested. mornellas13@gmail.com
I am interested in some of the bolts-brackets . Trying to do the factory look
OP hasn't logged in since 2017......
You might want to try emailing directly. Good luck. |
Talked to Mike,he has no clue what he has left if anything.Tom
