Hi, I no longer get 12v to my a/c compressor on my 70. System is all original and has been working fine until now. Fuse in fuse box under dash is fine, all fan speeds work, and if I jump 12v to the compressor it works fine. So for some reason the compressor no longer getting voltage from the harness.
No sign of mice either. I just dont know if there is a relay or something else between the dash controls and the compressor.
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
There should be a fuse at the alternator for the compressor.
Check the ambient temp sensor located on the top of the cowl.
What he ^^^ Kenman said.
Ok, should have some time this w/e to investigate. About the fuse, I am aware of the hi speed fan fuse in that location but not for the compressor. I will look for the ambient temp sensor but I am not aware of any such sensor on a 70. What am I looking for exactly and how to check it?
70 AC Fuse
![]() Quote:
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. ![]() |
Guys, thank you for all the replys. Unfortunately I haven't been able to get back to this yet, (arrgg, short daylight hrs and too much work). I did follow the compressor's 12v lead from the compressor back to the harness at the firewall, no fuses present just a harness to harness connection. A picture would be worth a thousand words to identify any of the components suggested in this thread. Merry Christmas!
I found the sensor on the cowl. Sensor has no voltage either except when I hot wire the compressor. So, sensor is probably not the problem. Hate to work blind but took a leap of faith thinking its most likely the dash switch. Sprayed a couple of quick shots of qd electronics cleaner in the slot where the switch arm comes through the face of the control panel, flipped it a few times and bingo! 12v to the compressor!
COOL!
Thank you John!
