what makes that sound
that sound that a diesel motor makes you know that ratel or nock
if your gas e motor made that sound it would go to the shop to get rebuilt but a diesel motor makes that sound all of its life and everything is good what could make that noise and not do damage ?
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
Injectors .....
nope i dont think so remember gas motors have injectors to
It is heat and pressure induced ignition. It's called detonation (bad)in a gas engine but that is the way a diesel engine works.
Diesel engines are built much heavier than gas engines so it does not damage them. A lot of the new computer controlled diesels do not knock loudly anymore. |
the diesel ignites as it is injected in the hot compressed air so i dont think that is detonation
Correct.
In a diesel engine it is not detonation, it is normal ignition. In a gas engine it is detonation, not normal ignition. |
Some "official" terms for those that care.
Compression ignition engine = runs on diesel fuel, and that fuel ignites because the pressure and heat of compression is sufficient to light it off. Spark ignition engine = runs on gasoline, and during normal combustion the fuel ignites when the spark plug fires. Abnormal combustion (detonation or pre-ignition) occurs anytime the fuel lights off from something other than the spark plug firing. I have a little Kubota tractor with a 3 cyl diesel and man is it loud and "rattley" when it starts cold...
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Hehehe ... yeah, been starting my Kubota BX2200 in about zero degree temps lately.... acts like it's going to come out of the tractor for the first five seconds. Block heater helps.
The noise is from the rapid ignition of diesel causing a shock wave
Woodpeckers in the crankcase.
How many woodpeckerpower does your diesel have? 🤣
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
How many peckerpower does your wood have?
Yep, they are actually pretty quiet now.
Much tougher parts than what comes in the average gas engine. A somewhat local Olds drag racer, use to convert the Olds diesel engines to gas for his hot rods. He ran with the big dogs at the track with junk yard engines. Kind of like the turbo LS bunch is doing now. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Synthetic motor oil helps too. 5 or 10W30 synthetic will flow when conventional oil flows like cold honey. When it's REALLY cold outside. |
The fuel is NOT sprayed into the cylinder during the intake stroke. |
Right. The diesel fuel ignites as soon as it is injected. The injectors are timed, similar to spark plugs in a gas engine.
Of course now there is direct injected gas engines. I'm not sure when the injectors fire on them.
yes thank you
