Our Inland Empire GTO Club had its dyno day a few weeks ago, and I thought I'd share how my blue goat did. Total of 13 Pontiac's ran on the chassis dyno and my 670 iron headed 1967 GTO came in second in horsepower and first in highest torque at the rear wheels out of all the cars. It came in above 3 of the aluminum headed engines (2 Kaufman and 1 Edelbrock). All my runs were made through the mufflers and half the runs were made with the stock air cleaner in place on the Quadrajet carburetor. While the numbers show that there's more to the engine than what you can see, I did pull it back out of the garage last weekend and drove it 227 miles to the Midnight At The Oasis show in Yuma, AZ. It managed 14.3 MPG on the way to the show but a strong headwind on the way home cut the mileage to 12.4 MPG. The mileage around Yuma on the poker run and Friday cruise was a low 7.8 MPG, but I did a lot of irrational driving that the Yuma PD would have frowned upon had they seen it.
My son Mark's '65 2+2 was 5th overall behind two aluminum head engines but in front of the remainder of the iron heads. His 421 came in at 362.8 HP and 500.3 Torque at the rear wheels on a 12 year old build with a Crower 60919 cam and Rhoads V-Max lifters. Here's a quick rundown of our results: Owner..Horsepower..Torque.......CI & Notes Tim.........510.8.........517.4..........468 open header Kaufman 310's, solid roller cam Mick.......450.5.........527.1..........462 mufflers 670 heads Bill..........445.5.........465.6.........468 mufflers Kaufman 305's Tom........400.8.........465.8.........462 mufflers Kaufman 305's Mark......362.8.........500.3.........437 open header 62 heads Bruce.....340.9.........370.7.........442 open header 96 heads Jimmy....306.1..........387.3........400 mufflers 670 heads Rick W....316.2.........372.6........468 mufflers round port Edel carb problems Mark P....311.5.........363.4........462 open header 96 heads Rick H.....247.9.........317.7........406 muffler 16 heads Larry S....239.5.........333.3........400 mufflers 670 heads Dan........183.4.........259.4........400 mufflers carb problems Glin........151.5.........198.6........326 mufflers
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. Last edited by lust4speed; 03-08-2018 at 11:58 PM. |
WOW that is great
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
My car was rather anti-climatic on the dyno and just lifted up and made the pull, but Mark's car had probably the best attitude of any car out there that day. Here's the double pull of his car. His engine is only 9.1:1 compression. Mark's Pull
Great job with those iron 670 heads Mick, real sweet!
What would have shown even how good the iron heads are for motors of under 425 cid would have been if any of the 400 cid motors in your dyno day test had aluminum heads on them of over 200 CCs in port volume. Unless your building a 400 cid or less, true all out race motor then cylinder heads of over 205 CCs of port volume will be found to be counter productive in your quest for the best average power numbers! The factory had a total grasp on what size port was needed for max average power up to 5400 rpm, hence even with the 455 SD motor they went with 180 CCs of port volume. I guess the lessons 1969 of the RAV heads on the 400 motors was still leaving a bad taste in there mouth even in 73 ,and rightfully so!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 03-09-2018 at 07:48 AM. |
It's all about the combination and tuning. You can get it done with iron or aluminum heads but for sure it makes you feel better about your engine combo when it's using traditional parts like iron heads, factory carb/intake/distributor etc.
That's one of the main reasons I went back to a factory intake to sit under my factory carburetor. It goes better with the stock valve covers, HEI, and stock air clean and Shaker assembly. After you make a pass at the track folks are nearly in shock when they wonder by to take a gander at what you're using and see the stock appearance. Anyhow, nice job for sure and excellent numbers from the engine combination.......Cliff
That's cool! Would you have track times for your car or any of the others?
Nice dyno #'s!! I like to see iron heads prove themselves. Is it a lean condition or excessive fuel that creates all the popping and banging when you let off the throttle? Out of all the open headered race cars Ive had I think I only had one that would do that at the end of the track when you let off the gas/..
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Good to see a spread of data.
Were open-exhausts cars " opened-up to open headers for the test? |
Really good numbers for a chassis Dyno. They usually seem kind of deflating ( to your ego ) on paper because of the drivetrain loss. Or maybe it's just me.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Great data, thanks for sharing!
13 different Pontiacs, variety of heads, CID variance of 142 inches, and EVERY one of them made more torque than HP, yet nearly every build thread has something to the effect of, "I want ??? horsepower." If their cars weigh about the same and have equal traction, I'd love to see Mark and Tom race.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
What fuel?
Pretty cool! I like the assortment of engines.
![]() Quote:
I hope Jim Hand is reading this!!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
May I ask where you went in the IE to do the dyno? I'm close by and would like to have the info for future reference.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
The Stock Stock & SS racers have been making big power with iron heads for a long time. LOTS of 10 sec Stockers. And that's with low lift non-roller cams, near stock stroke cranks, heavy pistons, iron intake, & Q-jet. Randi Lyn Shipp's '67 Bird is the 1st that comes to mind. I think she's run in the 10.40's. And that's with 670 heads, a '67 iron intake, & a 750cfm Q-jet.
http://www.classracerinfo.com/Engine...4&MAKE=Pontiac https://www.dragracecentral.com/DRCS...r2017#indextop Also some 9 sec SS cars, with iron heads. The Burton 400 powered GT 3rd gen, from 2017, comes to mind. Greg Meyer also has a quick 400 powered GT car. Both these cars run low 10's . Not positive if both cars have dipped into the 9's or not. Maybe somebody knows. If round port iron heads count, that adds several 10 sec Stockers & 9 sec SS cars. Leo Glasbrenner, Scott Burton, Brad Burton, Keri Angeles Pari, and JB Clegg, come to mind. Norman Warling posted that Scott made a high 9 sec run with his Stocker, if I remember correctly. Seems like I remember somebody posting a chart showing aprox how much hp it takes to run a certain 1/4 mile speed. http://www.wallaceracing.com/hpcalculatorquarter.php Last edited by ponyakr; 03-09-2018 at 01:56 PM. |
Neat as can be.
The closer throttle blades are to shut, at idle position, the richer the mixture gets while backing off. That's why some do more backfiring than others. Lots of factory carbs had a dashpot that kept throttle blades from snapping shut. It kept the throttle blades partially cracked and bled down slowly to the idle position. Saved fuel and kept mufflers from blowing up. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Mick,
WOW, that is impressive numbers! with iron heads or Aluminum sounds like you have a nice combination and 14 mpg is pretty good as well. Mark compression in 9.1 to 1 what is yours and do they both use premium 91 octane. Thanks for sharing Jim
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
![]() Quote:
![]() Quote:
Anyway, first love is the dragstrip, but a day at the dyno can still be a great way to spend a Saturday. You get to hang out, tell lies, and it even feels like you can race a dyno by the end of the day...
