Old 03-19-2018, 11:54 AM
er455 er455 is offline
Default Boost and traction problems
Ok I have a turbo car 79 trans am and I am making 12# of boost right now on e85 and I am running a 28” tall M&H drag radial with a 3.08 gear with Turbo 400 , the problem is when I race anyone the car just spins as soon as the boost comes in and I lose every race because the boost comes in all at once ....is there a way to maybe bring boost in slower or ramp up ?? This is on the street at the track it would be ok I think ... I have the widest tire I can fit it’s 11” wide ....
Old 03-19-2018, 02:57 PM
JSPONT's Avatar
JSPONT JSPONT is offline
lower the boost, you should have a manual boost or electronic controller. 8 psi is about it on the street before tires are always spinning. 8 psi will hurt a lot of feelings anyway. What is done to the front and rear supension?
90-10's up front with a good set of Santuff springs help. Leaf spring car should not be to bad to get to hook.
Old 03-19-2018, 03:42 PM
Hey Jeff Yea I got used to 12# now and in 3rd gear it pulls hard the front suspension is Viking coil overs with there adjustable shocks set at 90/10 with a ws6 sway bar hooked up car drive like crap without it and the rear has dearched springs to lower the car 2.5” and cal track bars with stock shocks also has sub frame connectors was thinking if I could keep the boost at 6 or 8 in first and then after 2nd gear start increasing it to 12 some how maybe some kind of boost controller....
Old 03-19-2018, 04:19 PM
JSPONT's Avatar
There are boost controllers like that, I just did a bunch to my car in an effort to hook on the street but the street is a difficult deal. I was racing Charlie one night on a major hwy from a roll, doing about 50-60, 12 psi when I had the stick, built a little boost by stepping on the brake, let it go and almost nosed the car to the center divider. Tried again and it just spun, this was his nitrous Ventura, which hooks great.
I saw one controller with 3 switches I thought was cool. EFI guys can program to pull timing and fuel and have it ramp in. I am a poor guy so my foot has to control it. LOL Good luck.
Next set of radials try the MT pros. My friend had the M+H but said the mt's hooked better. Some say the opposite but it is worth a try.
Old 03-19-2018, 04:35 PM
I heard the same thing on the mt pros but I have 17” snowflake wheels so the m&h were the only one that were 28” tall ...
Old 03-19-2018, 05:12 PM
charlie66's Avatar
Get rid of the 17"s . You need 15"s ...You need side wall...
My Half AN Injun.....
Old 03-19-2018, 06:02 PM
JSPONT's Avatar
X2^^^^^^^^^^ I got rid of the 17's and it hooks way better, my tire in 29.5 tall on a 15 inch rim.
Old 03-19-2018, 06:23 PM
taff2's Avatar
taff2 taff2 is offline
Get a programmable timing box,MSD 7531 or 6530, let the boost build as fast as it can but pull timing to kill a bit of power wherever in the power range you need to.
Old 03-19-2018, 09:52 PM
bankbook's Avatar
bankbook bankbook is offline
AMS-1000
15 “ 29 or 30 inch tire
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 03-20-2018, 09:24 AM
Curious George's Avatar
Curious George Curious George is offline
https://www.leashelectronics.com/Boo...LER-BL2011.htm
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 03-20-2018, 06:53 PM
Originally Posted by Curious George View Post
I like this... Thanks for the link.
Old 03-21-2018, 01:03 AM
70 bird's Avatar
70 bird 70 bird is offline
I run a 6psi wg spring and when I get into 2nd gear a hit a button and get 12psi through a manual controller. You can rig this up for about $30.
Install a manual boost controller and set it to desired psi. then splice this into the supply line.
https://www.ebay.com/itm/12V-DC-1-8-...MAAOSwsXFZFq7h
Wire this up with a micro switch on your shifter and you have a poor mans two stage controller! And you can adjust the second stage while you drive. On my ford I have a few paint marks on the controller for settings up to 20.
Old 03-21-2018, 09:15 AM
Thanks 70 bird I like the poor man boost controller
Old 03-21-2018, 01:43 PM
GTOGEORGE's Avatar
Wish I could adjust my boost then bring it on later....my 60' is kind of insane!
GTO George
Old 03-22-2018, 08:45 AM
I'm loving mine so far. Our car club does a street 0-60 contest every year and this was a big help. Also makes changes at the track very simple.
