SUPPORT YOUR LOCAL STARTER
Since OHC 6 Starters are no longer avail it important to keep yours safe.
Many starters over the years have lost the factory support which is vital to keeping stress off the nose/cone that is prone to cracking otherwise. The support is a simple stamped steel bracket that bolts to the starter and then to the engine block hole provided for this support. So be sure to support yours!
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Hmm, I wonder if I have one in my stash of parts? Probably not, but could also probably make one. Using a Buick 455 motor in the OHC starting housing only adds to the force.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
Since I've been away from the OHC 's since the mid 80's, What is the diff between the OHC starter and other GM that mount on the pass side?
George
Chebby 6 Vs OHC 6
A Chebby nose/cone can be trimmed, but nothing beats OE.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-25-2024 at 11:07 AM. |
Thanks Jeff.
George
Good information! Always learning on this site. Thanks, Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Mr. Jeff, Is this going to be on the final exam? Should we be taking notes?
I like this classroom...................do you grade on a curve??????????? Very good and appreciated info Jeff...............how many probably never gave this a second thought...................
A quote from a man named Jim Elliot I like: "He is no fool who gives what he cannot keep, to gain that which he cannot lose" |
I don't Grade on a curve nor do I allow open books.
KNOW IT, LEARN IT, LIVE IT! To the back of the class with you...
