Old 05-07-2018, 05:38 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Gauge size
Are the gauges in the 63 LeMans the same size as 64 an 65?
Old 05-24-2018, 10:06 AM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
I think so!
Old 05-24-2018, 10:47 AM
tom s tom s is offline
I think I remember the 64 indash tach is the same size but the mounting of it is diff.Maybe Peter will chime in.Tom
Old 05-24-2018, 03:55 PM
Chiefkey Chiefkey is offline
Default Gauge Size
The tachometer is the same size. The only difference is the 63 Tachometer has a stud on the back of the casing to help mount the cluster in the dash. The 64 unit does not. I bought a 64 repro unit from OPGI and used some epoxy to install a mounting stud in the correct location. Works fine
Old 05-26-2018, 11:21 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 63 Lemans Tach vs. 64 GTO tach
First 2 photos, original 63 Tempest-Lemans tach.
Photos #3 and #4 = 64 GTO or Lemans factory tach.
Although used tachs for these years car are no longer common to find at swap meets. For the 63 Pontiac made 4 cyl tachs as well as V8 tachs.
For the 64 Lemans & GTO cars they made a 6 cyl tach as well as the more often found V8 tach. The V8 tach is the one you usually see. I would say a 6 cyl tach would be super-rare to find.
Usually the tach is ink stamped on the back for the proper cylinder engine it's calibrated to run off of. But sometimes that ink stamp fades away or gets scratched off by a previous owner.
Name:	63Lemans_tach Front View.JPG
ID:	483837   Click image for larger version
Name:	63Lemans_tach Rear View.jpg
ID:	483838   Click image for larger version
Name:	1964 GTO or Lemans in Dash Factory Tachometer Nice.jpg
ID:	483839   Click image for larger version
Name:	64_GTO indash Tachometer_A2.jpg
Peter Serio
Owner, Precision Pontiac
Old 05-26-2018, 09:30 PM
hobbygto65's Avatar
I was hoping a 65 tach would fit, a little easier to read.
Old 05-27-2018, 12:11 PM
The way those gauges are mounted I don't think that would work.
Peter Serio
Old 09-05-2018, 10:04 PM
hobbygto65's Avatar
It looks like if you bought the whole 65 gauge cluster it would bolt in. Maybe a few mounting mods but it looks doable. I have a 65 clock glass and it's exactly the same size.
Old 09-16-2018, 06:51 PM
hobbygto65's Avatar
I discovered that 65 GTO gauge pod will fit in a 63 dash housing, notice the Tach needle by the gas gauge.
ID:	492907   Click image for larger version
