Is there a left and right, or both sides interchangeable?
I should know this after 35 years LOL.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
on 65-66 big boats its the same...
Left is actually different but they will work both ways.
The driver's side mount kind of interlocks with itself so if the rubber breaks, it will inhibit the engine from hitting the hood.
Thanks!!
Next Question...
Finally crawled under the car, looks like the exhaust manifolds will have to be removed to get to those most forward bolts. Or, unbolt everything and raise motor several inches. Any ideas or tricks from you guys that have done this job "in the car" will be appreciated. Thanks!
I jack the engine up and break them loose with a box wrench or a long ratchet with a short thin wall socket.
