I have a virgin IA IIA block and a really nice set of 68cc E Wideports, very nice victor 4500 ported to the heads,T&D 1.6 shaft rockers. Plan is to run Boost in the form of a Procharger. Either methanol or Q16. I want this block to be usable for a long time so I want rebuilds left in it.
What bore/stroke should I go with? How many CI? |
What bore is the block currently? Personally i'd got 4.310bore (if that bore is possible), 4.250stroke
X 2 ....no doubt!
4.310 Bore X 4" Stroke.
496? Why?
Boost will make the torque 4 inch stroke will make for more RPMs alot of torque in a high RPM = greater HP .. in a apples to apples comparison.. be my guess
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
Unless your in need of well over 1000 hp and have the car set up to hook that power,I don't see the need for wide ports when your pressure feeding the motor!
My vote:
4.250 bore to give plenty of rebuild room and plenty of meat between cylinders. 4.00 stroke to keep more of the piston skirt up in the bore at BDC. With boost, you don't need cubes to make power. 454 cubic inches but let's call it 455 to be more Pontiac-oriented. ![]() JMHO, Eric
If I was to do it over, I would go less stroke. I have a 4.250 , I would like the 4.00 or less. You will still make plenty of power and piston skirt / wall will be better with the 4.00 stroke.
![]() Quote:
That's what I'd want for dimensions. |
X2.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Goal is more than 1200 Hp...car will be in the chassis shop all winter. I have all of the wide port stuff and would like to use it...
The bigger ports allow more flow per psi. Somewhat like an intercooler effect.
Yep, run em if you got em! |
![]() Quote:
Rich Guido just did drag week with his new turbo set up(65 GTO) to work out the bugs. Had trouble hooking with all the power and torque. He drove it 3000 miles round trip. His mph in the 1/4 was an 8 second car and that was at 10 psi. He ran in the 9's with 6 psi. |
Lots of bore left to clean up and los of meat in cylinders for strength. Stroke is a good stroke for the block height.
Sell your block and build a Chevy... less B.S.
NA or maybe N2O I'd agree.... Boosted he just doesn't need as much stroke. Yes plenty run big stroke boosted but blowers and turbos make more torque than adding stroke NA.
Im just gave my opinion and i stand by it.
My next motor will be a LS with a pair of turbos .. ..lol
