Old 07-25-2018, 08:50 PM
midway64 midway64 is offline
Default dry deck pluming
need help with dry deck pluming have no water flow in radiator ---aluminum block lines run from back of heads to block ???
Old 07-25-2018, 09:10 PM
GTOGEORGE's Avatar
To the back of the block, I crisis cross mine (No. 10 lines) . it makes it a little easier plumbing them that way.
GTO George
Old 07-25-2018, 09:40 PM
9secdport's Avatar
9secdport 9secdport is offline
You probably have an air pocket that isn’t allowing the water to flow. If you have access to a vacuum fill tool it should take care of the problem. I had the same issue.
old combo
70 firebird 3250# race weight
462 #62 d-ports best 9.60 @ 140.20
naturally aspirated
new combo
70 firebird 3280# race weight
523 HiPorts by EIC Motorsports
8.49@158.9 N/A
Old 07-25-2018, 09:57 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I've seen them get an air pocket before the water pump. Letting it sit over night would solve the issue. You can fix the problem by adding a bleed valve at the top of the water pump cavity on the timing chain cover.
Go fast, see Elvis!
Old 07-25-2018, 10:08 PM
GTOGEORGE's Avatar
I get it all the time after I have drained the water out. I normally crack the fitting on one of the no.10 lines and force air into the radiator!
Sorry I mis-understood want you wanted with my 1st post.
GTO George
Old 07-26-2018, 05:42 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Mine - but it's an IAII.
Old 07-26-2018, 05:43 PM
Other side pic.
Old 07-26-2018, 05:44 PM
Up close - yes, there's plenty of clearance with the Ford style d-cap to the driver's side rear.
Not an aluminum block. Not dry decked.
Old 07-27-2018, 03:22 AM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Air in the system. Jack the car up and down with the engine running. Also add an air bleed/vent valve at the HIGHEST point in the system. Also make the fill point of the system at the highest point also.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 07-28-2018, 03:07 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
I’m sure a stupid question......but what the purpose for closing off the water holes in the head?
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 07-28-2018, 03:13 PM
GTOGEORGE's Avatar
So water doesn’t get into the combustion chamber under load via the deck area. Water doesn’t compress there for .......no boom, boom!
GTO George
Old 07-29-2018, 09:24 AM
Gotcha
Old 04-03-2020, 09:58 PM
punkin punkin is offline
Any chance you have a photo of the other side? Looks like water flows up from the block, into the head but then where does it go?
I thank you.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 04-04-2020, 07:16 AM
taff2's Avatar
taff2 taff2 is offline
Midway, are you reverse cooled as well? Electric or belt drive water pump?
Old 04-04-2020, 07:56 AM
chuckies76ta's Avatar
That is some nice S/S fittings. Any chance pointing us to manufacture or part number?
Charles
Old 04-04-2020, 07:59 AM
That's a hell of an idea. I always leave the thermostat housing off while filling the rad to let air out of the block and heads.
Charles
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 04-05-2020, 02:49 AM
Dragncar Dragncar is offline
Charles
You can just drill a 1/8" hole in your thermostat and it does the same thing. Thats enough to let out any air while filling and does not effect the thermostats operation.
Done it for years.
Old 04-05-2020, 08:50 AM
PAUL K's Avatar
Done it for years.
Unfortunately that doesn't work on a dry decked application...but that will allow the thermostat to open so you can block the water transfer hole on the timing cover for improved cooling.
Go fast, see Elvis!
