2018 Norwalk’s (tri-power) official racing thread
Hope this thread stays!
I’m loaded and ready to roll, leaving in the morning! Safe trip for everyone! GTO George |
I can see it !!!!!! Not blind here.
Good luck George. Get that 7. |
Good Luck to all and safe travels!
George I hope you will post updates
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23 |
Good luck George!
Ill stop by and say hello..
My Half AN Injun..... |
Heading out 4am ish tomorrow morning with Torquewar......
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
I’m loaded and ready to roll, should be about 12 hours on the road. I’ll swing by and say Hi George.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
9am and there are 12 rows of cars/rv’s with anywhere of 15-20 in each row in Linders Lot!
GTO George |
Made it to my first rest stop in Richmond, about 500 more miles to go.
Good luck to all. Keep us posted. Hope the board will be working again.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Left Norwalk at 7:40 To drive to the track Got in Around 8:30
# 124
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
Car count........223! 11:30am
GTO George |
Best of Luck to everybody.
What does the weather look like for the weekend? Stan
210 furthest I've been ever,got here about 10.30. Hope everyone has a safe trip. Police on turnpike and 20 coming from Pittsburgh. Weather seems great. Let's get registered.
Over 254!
GTO George |
Just pulled in at number 307. Two more behind us
Pits are almost completely FULL.......and it’s only Thursday!!!!
GTO George |
Pretty impressive. No car this year but been doing a scouting trip for next year..
No doubt! Turn that biotch up! Don't worry about a trophy for a bracket rave "win". Go fast! 👍😂😂😂
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners '78 Lemans - Drag car project |
There’s cars here I have t seen before, I’m telling you this place is packed! GTO GEORGE |
Live feed?
