Old 09-27-2018, 01:30 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Steering damper
Do any of you have this option, is it factory? It looks like it bolts on where power steering arm would be. Sorry, not very good photos. The one bolt is broken that's why it's hanging down.
ID:	493763   Click image for larger version
Old 09-28-2018, 02:18 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Difficult to tell from the pics, but looks like it could be the power steering cylinder.
Old 09-28-2018, 10:13 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default OEM
A steering damper was available on 63 Tempests. The shock mounts to a bracket bolted to the frame and to the steering link by u-bolts. A replacement shock absorber that will fit is availble from Monroe, #SC2914.
Old 09-28-2018, 03:25 PM
1lms 1lms is offline
Damper was also available on 64/5 Tempest LeMans with manual steering. I have one on my 65.
Old 10-02-2018, 03:28 AM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Yes, my 63 had one ... it worked against a stock PS bracket. Nice design ... occasionally you see one on a 63 ... not sure that it came from the factory that way. I might have some pictures some place, Also, 63 - 67 Corvettes all used one. John
Old 10-02-2018, 05:46 AM
Jeff Hamlin's Avatar
IIRC we still have the Factory Damper removed from the '63 Tempest.
This car was a non-power car. I'll see if I can locate it.
Old 10-02-2018, 09:27 AM
beemergary's Avatar
I got one on my 63.
