THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
So the top post terminal on the negative side won't tighten down any farther and the battery shims I've found are for the larger positive post, is there any reason why I can't use some copper shim stock? Just wondering if there could be an undesirable reaction between the lead post and the copper.
1963 Catalina 2 door hardtop 1968 Catalina 2 door sedan |
Are you using a positive cable on the negative side? They are bigger diameter.
Lead, copper, nickel, gold, silver is fine.
Some brass is fine, and others not. Suspect: alum, magnesium, iron, some stainless not so good. All about affinity to transfer ions; electroplating |
This ^
No, it's the factory cables on a 2008 Honda CRV. I can tighten the clamp to the max and still lift it off with two fingers.
I'd say a copper shim is ok...coat the outside to minimize the green stuff growth...(copper sulfate, I believe).
george
I have seen them, no idea who made them... these were lead...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
What about new cables, new battery, or both? And I assume it's a top post battery right?
I've seen it a couple of times years ago. One of the above or both fixed it. And yes it was on one of my cars with Sears batteries and worn out cable clamps.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
it is a brand new battery, new cables are out of the question as this thing is wired much differently than our old Pontiacs. I've got a lead shim on the positive side but the negative post is much smaller diameter. I'm going to use the copper but I just wanted to make sure the copper wouldn't interact with the lead and cause a bigger problem.
When you think about it, copper wire is "molded" into the lead clamp. I would think a copper shim would be fine. I'd even use a small sheet metal screw threaded in between the clamp and battery post. Would look the prettiest, but would be tight. Maybe even tighter than with the shim.
If you are not going to change the end at least, and want a quick fix, try this. Take the nut off put a larger nut over the threads and put the original nut back on against the bigger nut and tighten up.
Let me know if you need some lead shims. I got them from Western Auto in 1969 and haven't found a use for them yet.
http://www.pontiacpower.org/ |
An easy way to close it up some is to oval it with a BFH. Yeah, it won't work as it should (less contact area) but it will (assuming it didn't crack) work.
Is there anything hammers can't fix? ![]() |
https://www.autozone.com/batteries-s...31027_310094_0
I had to use two of these on the old ladies 2014 Accord because of corrosion, just cut, strip, insert and tighten.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
The clamp is maybe "stretched" from over tightening. If you can, get vise grips and straighten the round area to make the hole smaller.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 09-29-2018 at 02:23 PM. |
Fiedlerh, I've never seen lead shims like that.... ever. I thought someone was pulling our leg.
I've done the larger nut trick on the bolt to tighten up the clamp. 63, put some die-electric grease on the terminals to keep away corrosion.
They used to sell them in hardware and auto parts stores. Back then, I guess it was more common for battery posts to corrode away or battery clamps to stretch out. I remember back then people tried all sorts of tricks to make a battery last longer like using miracle additives and charging schemes.
