Old 10-09-2018, 05:30 PM
musclecarman15 musclecarman15 is offline
Default original honeycomb trim ring identification
how can you identify original 15in honeycomb trim rings...thx keith
Old 10-09-2018, 07:11 PM
They are the same as a Monte Carlo poly wheel trim ring.
Old 10-10-2018, 10:44 AM
thank you,but I need to know how to identify originals,thx keith
Old 10-21-2018, 10:03 AM
GETRIDAONE's Avatar
GETRIDAONE GETRIDAONE is offline
The originals are the ones with dings & curb rash.
I noticed original mounting clips appear to be painted black instead of being black oxide coated.
Old 10-22-2018, 10:13 AM
thx,can anyone post pictures,thx keith
Old 10-26-2018, 04:59 PM
Jim Rotella Jim Rotella is offline
Just for the record; the Honeycomb trim rings are very similar to the trim rings on the Monte Carlo's poly-cast wheel, but they are not the same. They will still fit on the Pontiac wheel, but if you compare them side by side, you'll notice the difference. There was a 15" Buick Regal poly-cast wheel in the 80's that used the same trim rings as the Honeycombs.
