Looking to buy all of the necessary parts to convert my 64 GTO that was originally no power steering to power steering. Car has no A/C. but thinking of adding Vintage Air, if pulleys are different. Thanks.
Pm sent your way
PM sent.
![]() Quote:
Normally it is recommended to add a third pulley to the backside of the crankshaft but the original 64 crankshaft pulleys are too flat so the add on pulley hits the outer edge instead of the center hub. If you want to run a seperate belt for the PS, alt and AC I would go with the 65 PS and alt setup and the 65 crankshaft pulleys. The crankshaft pulleys have a deeper hub which will allow the third pulley to mate against the hub of the crankshaft pulleys. I am currently running the first scenario, which works but I do occasionally get a belt chirp when using the AC. I plan on going to the second scenario. I have all the parts except the power steering bracket, which I can get a repro from a couple places. ![]() ![]() Sent from my XT1080 using Tapatalk
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight! |
Thanks for the info. Anybody have a 65 power steering and alternator setup for sale?
![]() Quote:
Ran it a while with the AC running and no belt chirps when the compressor kicks in. I will have to wait until it gets a little warmer this weekend to give it a true test. So far so good. Sent from my XT1080 using Tapatalk
![]() Quote:
![]() ![]() ![]() ![]() Sent from my XT1080 using Tapatalk
Almost had a catastrophic failure, pulled out of the garage and noticed a big puddle that ended up being power steering fluid.
The return line started leaking. It is one of the retro ones I think I purchased through Rock Auto, I have to check my receipts. Anyway the pinch clamp did not hold. I was able to pinch it tighter with a horse hoof trimmer to at least keep it from leaking. Since it is the return line I am going to get a 5/8" screw clamp to add to the pinch clamp. If you have replaced this hose be sure to check the pinch clamp. Sent from my XT1080 using Tapatalk
