Old 10-25-2018, 05:59 PM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
Default Bumper Bolts Torque with Spacer
I'm installing new bumper bolts, nuts, and new rubber spacers. With the rubber spacers between the bumper and the bracket, is there a torque specification to tighten the nuts, or just a certain amount of "squeeze" on the rubber spacers so as not to crush them.
Thanks.
Old 10-25-2018, 06:20 PM
Rubber?
Old 10-25-2018, 06:39 PM
Tom Vaught's Avatar
Boost Engineer
I removed the front and rear bumpers of of my 64 GTO and do not remember any rubber spacers. Believe everything was "hard mounted" in 1964-65 time period.
Tom V.
Old 10-25-2018, 07:46 PM
johns johns is offline
You may want to use a little dum-dum on those bumper bolts-
John
Old 10-25-2018, 09:51 PM
Here's a diagram from a '65 Service Manual. They're part # 17, Rubber Spacer about 5/32" thick. They go between the bumper and the bracket.
Name:	1965 GTO Rear Bumper Diagram .jpg
Old 10-25-2018, 10:14 PM
There definitely is a rubber gasket/spacer between the bumper brackets and bumper on the '64s, I've taken a few untouched originals apart and for sure they came with the rubber pieces.
Just tighten the bolts down like you would any other similar sized fastener, nice and tight and don't worry about the rubber squishing out.
Old 10-25-2018, 10:34 PM
SR-71 SR-71 is offline
The nuts are place lock nuts designed to stay wherever you stop tightening them. Tighten them to get the brackets where they need to be and you're done.
