My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
At some point I'll kick myself for not buying them.
Shouldn't the seller have said '55-''60?
No reverse cooling in 1960. Seller got it correct.
These should be used as a pattern for reproduction of them in stainless. Unless CPR or somebody else is already doing that?
Jim K in PA 1967 GP HT 428 1967 GP convert 428 1957 Chieftain 4D HT |
Got used ones for a third of that
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Are there any suggestions on removing them. I have tried several times and cannot seem to get them to move. Billk
Bill, PM sent
I pulled mine out with a pair of duck-billed pliers and a lot of gentle shaking. If I were to try it again I'd fill the water jacket with a citric acid solution, let it sit for a while and the try the pliers. Be gentle.
X2. With NOS originals, replica's could be produced fairly easily and sold at a reasonable price.
Brought this up again to illustrate one point. In Post #3, the post says that 60 ponts didn't have reverse cooling. That is true. But the 1960 heads have a lot of casting similarities with the earlier gusher heads (1955-1959). You can slide the gusher tubes in a 1960 head with no problems. I tried and it worked. Larry Gordon @PontiacSafari.com gave me this nugget. Now I can use my 60 heads on a 58 Pontiac engine. Add the gusher tubes, water elbows on the front of the heads.
1961 heads have some remnants of the reverse cooling system as well - there's an opening on the front of the head that's filled with a freeze plug. Don't know if they can be converted or not, though.
I don't know about the 61 style heads but I've got 1974, #46 heads on my 57 block [bored .125" for 370 cu in] and the tubes don't fit. Drove the car all last summer and had no overheating problems.
Roll around in the excitement |
Just a little follow through....still driving the same car/engine with no problems.
