Old 01-06-2019, 09:18 AM
er455 er455 is offline
Default 4L80E
Anyone using a 4L80E transmission with boost ?
Old 01-06-2019, 09:34 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Rossler Turbo 400 "TH210-XHD" here.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 01-06-2019, 10:55 AM
A 4L80 is basically a TH400 with an overdrive. Tons of people running them N/A, Boost, Nitrous, etc. Talk to one of the one of the better known O.D. builders like Art Carr or Performabuilt.
Old 01-06-2019, 11:13 AM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
Are you just asking if they work with boost? Thousands use them as its a good choice for OD in a street car. I went 700r4 only because it was 18yrs ago annd the 4l80 wasn't a viable option then but will be using one next. Actually already built under my bench waiting for me to finish the motor
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
Old 01-06-2019, 12:22 PM
Half-Inch Stud's Avatar
3-4 Upshift is firm and low-latency. I don't have Boost, just porting.
Old 01-06-2019, 06:04 PM
Default 4l80e
Well I have a 400 now that is we’ll built , but I want to keep it a automatic shift under boost I currently have a check valve on on modulator and it’s working ok on the street but with a 4l80e the shifts are programmable and do not require a vacuum modulator but requires a lot of mods like adaptor plate, shorter driveshaft , speedo adaptor , trans computer , new convertor , etc ,
Old 02-20-2019, 12:04 PM
ERIC AULL ERIC AULL is offline
Yes, I have a 4L80e behind my blower motor in my GTO...love it....cost is high but it is a great trans. and works well. What exactly do you want to know? My trans. was built by CK Performance on Long Island. 1967 GTO....ericaull@yahoo.com
Old 02-20-2019, 04:01 PM
Are you letting the controller shift your car automated? I like the fact you can basically tune the trans like shift hardness , shift points ,
