Old 01-25-2019, 07:53 PM
Hank Hank is offline
Default 66 389 Build
Can anyone tell me what i'm gonna have to do to put a set of 670 heads on a 66 389?
Old 01-25-2019, 07:59 PM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
I think youll need new pushrods & head bolts for center port at exhaust flange part of head
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
Old 01-25-2019, 08:02 PM
tom s tom s is offline
Just make sure you order 67 400 pistons as the valve reliefs are in a diff location.DONT get the pistons with 8 reliefs!Tom
Old 01-26-2019, 12:02 AM
You can use your stock 389 pistons as long as you use a stock 389 cam if you are just trying to change heads. If you are rebuilding the motor by all means change the pistons to 400 cid pistons. If you are trying to run a high lift cam you will also have to change pistons.
Old 01-26-2019, 08:16 PM
What about the push rods?
Old 01-26-2019, 08:26 PM
Depends what your going to use for studs,rockers etc,sure you will need new but determine that after the engine is together.Tom
Old 01-26-2019, 08:39 PM
Default 66 389
I was just going to use the studs and rockers that came on the 670's
Old 01-27-2019, 12:38 AM
Use the same pushrods and rockers that the '67 670 heads would have come with. The '66 389 pushrods and rockers won't work with the 670 heads.
Head bolts are different between 400 and 389 engines. Not sure if it's just the center exhaust side bolt that's different. I would try to use a complete set of '68 or later head bolts, some low-performance '67 engines still used the earlier 389-style heads.
Old 01-29-2019, 07:34 PM
geeteeohguy's Avatar
This^^^. As long as you stick with a factory cam or go only a bit larger, no issues. I did the reverse back in the day, installing standard 400 pistons in a 389 punched .060" to save money. Ran a pretty hefty Sig Erson Hi Flow 2 cam in that engine, with no issues, running the '66 389-421 093 heads.
Jeff
