Old 02-28-2019, 09:04 PM
WARCHIEF400 WARCHIEF400 is offline
Default 1970 GTO Parts
1970 Rally Gauges face in great shape, worked before pulled $550.00
1970 power brake booster $50.00
1970 lower main duct and vents $125.00
1970 Intermediate steering shafts $50.00
1970 Rear Windshields $80.00
1970 Coils $25.00
1970 Oil Filter housings $85.00 each
1970 front lower window reveal molding $60.00
1970 rear front upper fender chrome moldings $30.00 pr.
1970 Throttle cable $45.00
1970 Turbo 400 Transmission oil pans $50.00
1970 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1970 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1970 door vents pr. $20.00
1970 positive battery to starter heat shield tube,
1970 window regulators set of 4 $150.00
1970 brake pedal assembly $100.00
1970 emergency brake pedal and bracket $75.00
1970 rear license plate bracket and holder
1970 water thermostat housings $20.00
1970 door hinges $50.00
1968-72 points distributors $80.00
1970 wiper transmission assembly (2) $75.00
1970 blower motors $25.00
1970 a/c inner boxes $150.00,
1970 headliner bows $50.00 set
1970 Power Front Disk Master Cylinder $45.00
1970 AM &FM RADIO PULLED OUT IN 1983 WORKS $475.00
1970 AM RADIO WORKS $200.00
1970 Harmonic balancer $50.00
1970 GTO Front Bumper prep by body man been off car for over 30 years $1500.00
1970 Quadrajet Carb pulled off running car #7040263 $375.00
1970 GTO Front Bumper Grills $475.00 all tabs in place in very good condition
1970 GTO grills repaired $300.00 for pair $150.00 singles
1970 GTO Front bumper to frame brackets $350.00
1970 GTO Front Headlight housing assemblies $250.00
11 Bolt Timing Cover $110.00
11 Bolt Timing Cover withy divider plate and pump $150.00
1970 Full length windage trays $85.00
1970 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00
NOS A/C Delco PVC $9.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
NOS Three prong Thermo Switch for rally gauges $250.00,
1971 GTO Rear Taillight lenses $150.00 Each
1970 Rear Taillight housings $75.00 Each
NOS 1970 Wheel well moldings $850.00
1970 pair of used rear wheel molding $200.00
1969-72 Goldenrod/Tan & Pewter/Gray PEWTER steering wheels crack free $125.00
1969-72 auto shifters $135.00
Fuel escentrics $35.00
1970 harmonic balancer $50.00,
flexplates $35.00
1970 inside glove box liner $45.00
1970 Standard Gauge & Speedometer cluster $65.00
1970 GTO/LEMANS Rear window Defroster Switch with wiring harness $150.00
assorted stainless moldings,
1970 driver side lower black dash metal trim $50.00
1970 radio rear support bracket $25.00
1970 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
1970 door glass $100.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
1970 pillar post covers $45.00
new points and condensers __________________
Timmy Mallory Email me at temallory@msn.com __________________
Timmy Mallory
Old 03-18-2019, 10:18 PM
rally gauges have been sold
Timmy Mallory
Old 03-20-2019, 01:33 PM
Mr Dave's Avatar
Mr Dave Mr Dave is offline
Do you have any body parts or partial parts? I need part of the drivers side quarter panel that is at the lower left corner of the back window, between the window and trunk to patch where the vinyl top was on mine.
70 LeMans Sport
95 Corvette
07 F350 Crew Cab 4x4
Old 03-21-2019, 03:52 PM
Sorry Mr. Dave all my 1/4 panels and sectionals have been sold
Timmy Mallory
Old 03-22-2019, 07:21 PM
Mr Dave's Avatar
Thanks for the reply.
Old 06-23-2019, 11:39 AM
455abody 455abody is offline
Do you have any altenator brackets for a 70 Goat?
Old 06-27-2019, 10:33 AM
all out of 70 alternator bracket
Timmy Mallory
Old 07-12-2019, 05:53 PM
racerboy's Avatar
racerboy racerboy is offline
PM sent
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 07-27-2019, 10:53 AM
pewter steering wheel has been sold!
Timmy Mallory
