Old 03-02-2019, 10:01 PM
Cardo's Avatar
Cardo Cardo is online now
Default POA valve finish
Does anyone know what the correct original finish is on the POA valve? - I'm thinking it was zinc plated but not sure. I had mine emptied out and welded back together, but want it plated correctly. Here is what i am doing. https://www.shopcenturyautoair.com/s...it_POAELM.html It comes back painted, which is what i expected. I would like to get it plated to the correct finish.
"I know just enough to keep me here, but not enough to get me out"
Old 03-03-2019, 09:11 PM
61vette 61vette is offline
You are correct, the original finish was clear zinc. They also had a gray paint sealer around the welded area. Classic Auto Air restores POA valves and will restore the original finish.
Old 03-05-2019, 07:50 AM
RedDirtRoad RedDirtRoad is offline
I was on classic Auto Air site but didn't see anything about refinishing POA valve
The site seems geared to aftermarket AC systems and not factory AC parts
Do you have s link for the POA refinishing from them?
Old 03-05-2019, 09:06 AM
Cardo's Avatar
Look here. https://originalair.com/restoration-gm-poa-valves I chose to eliminate the internals and go with the temperature cycling.
