I am purging my Pontiac parts stash. Everything listed is for a 68 GTO convertible except where noted. Parts range from repro NIB to unrestored original condition, some are noted in the description.
I will be at the All Pontiac Swap Meet at the Franklin County Fairgrounds in Hilliard, Ohio on March 10. I prefer to sell there vs online to save the hassle of paying for or arranging shipping. Below is a fairly comprehensive list of what I am bringing with me, there are other small items that will also be there that are not on the list. Jim N333CB fan belt (new) - A/C - $38 N333GB alternator belt (new) w/AC - $38 Door edge guards - original - $75 Cowl screen (repro) and brackets (orig) - $30 Quarter glass trim (vert) - $15 Convertible top cylinder - $75 Ignition points, wire, and grommet - $10 Fuel tank (orig) - $20 Convertible frame parts - $20 Rear quarter glass (orig hardtop) - tinted - $75 Rear quarter glass (new - vert) tinted - $200 Brake booster (repro) - needs rebuilt - $40 Ralley II wheel center caps (red PMD) - $100 Convertible top pump - original, needs rebuilt - $75 Convertible top pump reserveoir plug - $1 Radiator to core support isolators (repro) - $5 Fuse block to power window wire (repro) - $5 Fuel pump fitting - $5 Throttle spring - $2 Thermostat 180 degree - $2 Oil pressure sender - $5 Steering column bracket adapters - $5 GTO floor mats (aftermarket) - $2 Front end rebuild kit (unopened box) - $350 Air cleaner housing (orig) - $140 Pinchweld moulding clips - $15 Parking lamp lenses (orig) - $20 Fuel tank sending unit (new) - $15 Power top motor harness (M&H) - $20 Air cleaner breather tube (orig) - $1 AC hose (repro) - $20 AC condensor brackets - $5 Convertible top cable (orig) - $15 AC muffler (orig) - $2 Turbo 400 shifter cable (orig) - $2 Bucket seat bracket (orig) - $2 Alternator strap (orig) - $10 Distributor vacuum advance - $10 Bucket seat back panel brackets (orig) - $2 4 gang power window switch - $40 Rear quarter marker assembly (orig) - $10 Power antenna nut (repro) - $5 Disc brake distribution block (new) - $40 Fan clutch w/bolts - $10 Convertible top frame staple insert (roll) - $10 Driver door latch (new) - $65 Tilt column turn signal switch (new) - $35 Hideaway headlight switch (new) - $75 Convertible top motor mounting grommets - $5 Turn signal lever (new) - $20 Flasher knob (new) - $5 Splash shields (new) - $10 Pontiac script visor mirror (new) - $25 Voltage regulator cover (new) - $2 Hood insulation pad clips (new) - $2 Dash insert clips for dash pad (orig) - $20 Harrison AC box sticker (new) - $2 Front end bolt kit (new) - $20 Convertible door strikers (new) - $25 Gas cap - $2 AC mounting hardware & spacers (new) - $10 Emergency brake parts (orig) - $5 Quadrajet throttle arm (orig) - $2 Alternator - $10 4 barrel “140” intake - $125 Misc. interior screws (new) - $5 Seat lock hardware (orig) - $5 Front core support bolts & nut plates (orig) - $2 Blower motor vent tube (orig) - $5 Parking brake cable set (new stainless) - $170
R68GTO 1969 Camaro COPO 427 "RAT'S NEST" |
If you decide you would want to ship something, I would like to have the 68 door edge guards for my 68 convertible if they are in good driver condition.
Thanks, Bryan |
I'll let you know if I still have them after tomorrow's swap meet in Hilliard.
Door edge guards - original - $50
Cowl screen (repro) and brackets (orig) - $30 Quarter glass trim (vert) - $15 Convertible top cylinder - $75 Ignition points, wire, and grommet - $10 Rear quarter glass (orig hardtop) - tinted - $75 Rear quarter glass (new - vert) tinted - $200 Ralley II wheel center caps (red PMD) - $100 Convertible top pump - original, needs rebuilt - $75 Fuse block to power window wire (repro) - $5 Throttle spring - $2 Thermostat 180 degree - $2 Temperature sender - $5 Steering column bracket adapters - $5 Front end rebuild kit (unopened box) - $350 Air cleaner housing (orig) - $140 Pinchweld moulding clips - $15 Parking lamp lenses (orig) - $20 Fuel tank sending unit (new) - $15 Power top motor harness (M&H) new - $20 Air cleaner breather tube (orig) - $1 AC hose (repro) - $20 AC condensor brackets - $5 Convertible top cable (orig) - $15 AC muffler (orig) - $2 Turbo 400 shifter cable (orig) - $2 Bucket seat bracket (orig) - $2 Alternator strap (orig) - $10 Distributor vacuum advance - $10 Bucket seat back panel brackets (orig) - $2 4 gang power window switch - $40 Power antenna nut (repro) - $5 Disc brake distribution block (new) - $40 Fan clutch w/bolts - $10 Convertible top frame staple insert (roll) - $10 Driver door latch (new) - $65 Tilt column turn signal switch (new) - $35 Hideaway headlight switch (new) - $75 Turn signal lever (new) - $20 Flasher knob (new) - $5 Splash shields (new) - $10 Hood insulation pad clips (new) - $2 Front end bolt kit (new) - $20 Convertible door strikers (new) - $25 Gas cap - $2 Quadrajet throttle arm (orig) - $2 Alternator - $10 4 barrel “140” intake - $125 Misc. interior screws (new) - $5 Seat lock hardware (orig) - $5 Front core support bolts & nut plates (orig) - $2 Blower motor vent tube (orig) - $5 Parking brake cable set (new stainless) - $170
Thanks!
TTT - updated the list, removed the sold items and adjusted a few prices. If you're interested in an item, I'll send you pics.
Door edge guards - original - $50 Cowl screen (repro) and brackets (orig) - $30 Quarter glass trim (vert) - $10 Convertible top cylinder - $65 Ignition points, wire, and grommet - $10 Rear quarter glass (orig hardtop) - tinted - $70 Rear quarter glass (new in box - vert) tinted - $175 Ralley II wheel center caps (red PMD) - $90 Convertible top pump - original, needs rebuilt - $75 Fuse block to power window wire (repro) - $5 Thermostat 180 degree - $2 Temperature sender - $5 Steering column bracket adapters - $5 Front end rebuild kit (unopened box from Ames) - $300 Air cleaner housing (unrestored with PP silkscreen) - $130 Pinchweld moulding clips - $15 Parking lamp lenses (orig) - $20 Fuel tank sending unit (new) - $15 Power top motor harness (M&H) new - $20 Air cleaner breather tube (orig) - $1 AC hose (repro) - $20 Convertible top cable (orig) - $15 Bucket seat bracket (orig) - $2 Alternator strap (orig) - $10 Distributor vacuum advance - $10 Bucket seat back panel brackets (orig) - $2 4 gang power window switch - $40 Power antenna nut (repro) - $5 Disc brake distribution block (new) - $40 Convertible top frame staple insert (roll) - $10 Driver door latch (new) - $60 Tilt column turn signal switch (new) - $35 Hideaway headlight switch (new) - $75 Turn signal lever (new) - $20 Flasher knob (new) - $5 Convertible door strikers (new) - $20 Alternator (1977 reman)- $10 4 barrel “140” intake (Dec. 1967 date)- $120 Seat lock hardware (orig) - $5 Parking brake cable set (new stainless set from Just Right) - $160[/QUOTE]
