I know that 14” factory wheels can be a problem with disc brake conversions, but my understanding is that my factory 14” XE steel wheels “should” work with the Ames and Inline Tube factory OEM style disc conversions since the XE was compatible with the optional disc brakes in ‘70. Have you encountered issues with XEs on these conversion kits? I’m not interested in changing wheels.
Also, would the 2-piece rotor be the “correct” one for ‘70? Thanks! Sent from my iPhone using Tapatalk
Kyle Kruszewski
If the kits are true OEM style i can´t see why the XE rims would´t fit?
AFAIK the two piece rotor was used at the time as the JL Rally II´s with black center caps were used, to the end of 1969. I don´t have the exact date available, but my memory says mid december 1969. |
Thank, Kenth. My thoughts exactly. It “should” work, but I’m curious if anyone has direct experience with the recent kits from Ames or Inline Tube. They don’t list the part numbers of the kit components, but I suppose I could ask for them to better know what I’d be getting.
Kyle Kruszewski
have a friend who bought ilt repro caliper mounting brackets. he went to test fit original disc brake rims and they interfered with the brackets. called ilt and was told, thats how they are, you have to grind the repro brackets. he immediately took them off (may have pitched them, not sure) and after sending out his originals for plating, is putting them back on.
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
