Old 03-23-2019, 07:45 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Default Multi valve Pontiac head?
Since there are quite a few aftermarket cast and a few billet head choices out there to choose from, it would seem the next step would be a multi valve layout.
Anyone know if some work has been done on a 3 or 4valve layout? Just conversation.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 03-23-2019, 09:32 AM
charlie66's Avatar
I agree, Would be the next step for all out performance.
I know alot of guys with less cubes and 4 valves per cyl making alot more power then the larger ci motors with 2 ..
I think theres a guy on FB that was doing something like that for a Pontiac..
My Half AN Injun.....
Old 03-23-2019, 11:00 AM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
there was something posted on here about a guy working on a three valve head, iirc. had pics too.
Old 03-23-2019, 08:27 PM
mgarblik mgarblik is offline
Mac McKellar knew the advantages of multi-valve heads in the early 60's. The couple of times I was fortunate enough to talk with him the conversation always moved toward 3 and 4 valve designs. He was also convinced the maximum benefit would come from OHC multi-valve designs as well. But it was a time of cheap fuel and low cost engines. Need more power, just make the engine larger, much less expensive than exotic camshaft drives and 24 or 32 valves. Some of the benefits are negated if a pushrod system is retained, but OHC, I would love to see.
Old 03-24-2019, 12:25 AM
Dragncar Dragncar is offline
The 3 valve 428 car McKellar developed was given to him by GM as a retirement gift. Used to cruise it around town.
Oldsmobile made a 600HP 455 with a Q jet. 4 valve heads.
My Tundra has 4 valve DOHC Hemi heads. Its a very interesting engine. Smooth and powerful. The fly by wire throttle has some sort of lag. If it was a direct cable it would shred the tires. 14.56 in a 5700lb truck is impressive. Dead stock, just let the rear tires down to 20lbs and stab it in "drive".
I would love to get a engine and 6 speed trans out of a junkyard and shove it in a old Chevelle or something like that (no Pontiac's).
In conversations with high end head guys about 4 valve heads they say its nite and day better than any 2 valve head. Its where its at these days.
I always wondered why GM went with the 2 valve pushrod LS vs something like Toyota did with the 5.7 I Force. Toyota has to make special de tuned heads and blocks or they would run away from everything in NASSCAR.
I would like to see a takeoff of the 2 valve SOHC Hemi Pontiac tried in 1970. But in 4 valve. It would have real Pontiac roots. Even the purists would have to admit that. Its one way we could get around the bore space limits of our engines. Seems the old PMD engineers thought the same thing.
Old 03-24-2019, 12:26 AM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
The value on the intake side is pretty big. The value in the exhaust side is significantly less with the right valve timing.
Old 03-24-2019, 06:39 AM
steve25 steve25 is offline
The factory in the early 60s had a 3 valve head 421 built it was duel overhead Camed ( one Intake , two Exh) that had a the Intake ports layed out like the RA5 head and this is what to this day pisses me off when people say that the RA5 head was patterned after the later Ford tunnel port head, when it was not!
The RA5 head was based off of the head from this 1963 motor.
Old 03-24-2019, 10:56 PM
azbirds's Avatar
azbirds azbirds is offline
I forgot all about that three valve head. Somewhere I have some pictures of that thing.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!!
Old 03-24-2019, 10:58 PM
john marcella john marcella is offline
Why?
John Marcella
Marcella Manifolds Inc.
john@marcellamanifolds.net
ph. 248-259-6696
Old 03-25-2019, 02:04 AM
Stan Weiss's Avatar
Originally Posted by john marcella View Post
Why?
At exhaust valve opening / low lift there is a huge difference in pressure differential as to what the intake valve will see.
If we look at a 535 ci, (bore = 4.35", stroke = 4.5", rod = 6.75") 14.5:1 cr that has a peak cylinder pressure of lets say 1600 psi @ 12.5 ATDC there will still be about a 10th of that @ EVO.
Stan
Pontiac Pump Gas List
Old 03-25-2019, 07:17 AM
Stan
I was busting AQ's chops
John Marcella
ph. 248-259-6696
Old 03-25-2019, 03:04 PM
J.C.you's Avatar
how about a MMMVB? Marcella Manifolds Multi Valve Billet?
or take Dons Vs and intake and....just a few beads later.... walaaahhh ....done!
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 03-25-2019, 04:11 PM
Probably easier to ask Jeff Kauffman to do one.
He may be already doing something. He's already did a lot of things that the Pontiac racer needs or wants.
Old 03-25-2019, 04:20 PM
Stan Weiss's Avatar
If I was to think about doing a multi valve head. I could not see starting with anything but a clean sheet of paper. I would want to rotate the valves and have more of what would be called a flow throw (cross flow) design to try to maximize valve sizes and areas.
Stan
Old 03-25-2019, 04:25 PM
unruhjonny's Avatar
there was an SD-4 hemi head - strikingly similar to the Quad4 which came out at around the same time iirc...
I missed out on an auction for a nearly complete setup over a decade ago...
I don't know if it was ever officially released as a part of the SD-4 program - even though I seem to recall that around 1987 there was a hemi-head SD-4 "GTO" (Grand Am coupe) concept car in print...
I still think it would be pretty cool to find a nice solid 1985-1989 Grand Am SE coupe with the Iron Duke & 5 spd (I believe that 1989 was the last year you could setup an SE with that drivetrain) - and swap a complete SD-4 setup on it;
I get made fun of for liking those third gen Grand Am's (and Sunfires), but they are great little cars that can be alot of fun.
https://youtu.be/gIqRnfh-3k8
1970 Formula 400
Old 03-25-2019, 08:05 PM
Half-Inch Stud's Avatar
Valvetrain is truely the limit to my Fortitude, and surely other pay cubic dollars to get the Valvetrain to be on-par with the Bottom-End.
A blend of the OHC-6 with the Ford Modular Engine and YOU ARE HERE; a decent topology.
Roller followers being the most valuable player.
HP growth as seen in the Modular Engine APPLICATiONS as a guide.
Scale to the PMD Bore and I think there will be excitement.
Old 03-25-2019, 09:02 PM
J.C.you's Avatar
Stan
Stan u are a fuddie duddy, with too many numbers running through your bean. Just conversation thread ......so what?, if Marcella has to run a few more beads to lay the valves over?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 03-25-2019, 09:31 PM
I have had a 4 valve design in my mind for about the last 3 1/2 years now. And the groundwork for this to become a reality was laid down last month ! However it is for a very specific market. And I have serious concerns whether it will be outlawed within its classes that it's intended for.
A 4 valve retro fit is not something that I'm intrested in pursuing. To do something really good is complicated And extremely expensive for Valve train parts. And on a retrofit it gets even more complicated and the design gets compromised.
John Marcella
ph. 248-259-6696
Old 03-25-2019, 10:17 PM
Because it take energy to suck the ****e in. On the exhaust side only takes waste energy management which is free. The exhaust is not so important. You're trading off expansion vs. pumping work.
Why?
Old 03-25-2019, 10:18 PM
Are you sure? I"m pretty sure I can keep up. And shouldn't you be teaching this? Why are you asking me? Or is the magic fading? LOL
