Old 04-03-2019, 05:29 PM
indetrucks's Avatar
indetrucks indetrucks is offline
Question 68 GTO Timing Cover fit on a 67 with no mods?
So I just purchased this timing cover from eBay for my 67 GTO, then did research on the part # AFTER the fact like an idiot and it looks like it's for a 68. Part # 9790347
Will it still fit on my 67 with a new 67 water pump?
Edit* It looks like the only different is the size and location of timing marker based on this site:
https://butlerperformance.com/n-1341...ification.html
Old 04-03-2019, 09:57 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
you are correct... That is the only difference... It will bolt right up and work fine. The fuel pump bolts might be a different size, but that's no biggie...
Old 04-03-2019, 10:33 PM
indetrucks's Avatar
Great, thanks for the affirmation
Old 04-03-2019, 11:44 PM
Scott Thelander's Avatar
and the timing tab will be an inch away from the balancer
Old 04-11-2019, 09:23 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
67-68 water pump same depth?
Sent from my XT1254 using Tapatalk
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
Old 04-11-2019, 09:58 PM
67 and 68 = 4" ... yes they are
your probably better off with the 68 timing cover ... so when you go to the 4 bolt pulley of the nice aftermarket balancers
and the newer lower pulley ... your timing mark will line up nicely ..
