Old 04-26-2019, 08:45 PM
straycat's Avatar
straycat straycat is offline
Default H/O Racing HC-02 Camshaft Question
I'm getting ready to install an H/O Racing HC02 cam in a 400 and want to know if there were different versions of it. I've seen HC02D mentioned on Wallace Racing and wondered if this is an updated version of the original. Anyone know if they had different lobe separations and intake centerlines? I guess putting a degree wheel on I can figure it out except it's been decades since degreeing a cam.
Old 04-26-2019, 10:22 PM
Pontiac Performance Author
There were several versions of the HC-02, but they were all around 232/244 on 112CL , with lifts varying from .480" to .500". I doubt any of them would run any differently in a given engine. Set it up for a 108 deg ICL and you will be good to go.
Old 04-26-2019, 11:50 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Ken,
I studied your book when I was a kid and used your knowledge to launch my passion on my career. Much love and respect For what you guys shared. Thanks so much, Aaron
Old 04-27-2019, 06:16 AM
steve25 steve25 is offline
Since your posting about it there are many good things on line to follow thru on degree check that can guide you in getting it right.
Don't skip this part just because it may be new to you , get the biggest degree wheel you can find and a degree kit with the needed parts and then take your sweet time and do it right!
Just a matter of course I would advance the Cam with a off set keyway by 2 degree's just to compensate for normal chain stretch that sets in after 20 runs or so even with the best roller chain.
Old 04-27-2019, 08:25 AM
straycat's Avatar
Ken and Steve thanks for giving me the direction I needed.
Old 05-02-2019, 03:53 PM
straycat's Avatar
OK we degreed the cam but needed 4deg advance at crank to get a 108deg CL and a 113 1/2 deg lobe separation. Does this seem right?
Old 05-02-2019, 08:48 PM
tooski tooski is offline
Default HC-02
Mine needed a 2° offset at the cam (same as 4° at crank). Mine required 107° ICL as per cam 'card'. This is with an aftermarket double roller timing set, single keyways.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 05-03-2019, 01:45 PM
straycat and tooski make a good point as to why you should always degree a cam. We always had the HC-02s ground with a 108 deg ICL, regardless of vendor.
Old 05-03-2019, 03:01 PM
straycat's Avatar
Yea exactly Ken. We started with the cam straight up then went in the wrong direction retarding it. Oops wrong way then advanced it.
Old 05-04-2019, 12:07 AM
Had to chuckle at this, cuz I did exactly the same thing.
It was the first time I degreed a cam. I installed the offset key wrong thinking I was advancing the cam when I was advancing the cam gear, thus effectively retarding the cam.
Frank M.
75 Firebird
Old 05-04-2019, 08:32 AM
Half-Inch Stud's Avatar
Sounds like a darn good Street/Strip can; comparing to my 12.2 Sig
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
