Old 05-27-2019, 01:01 PM
rjpaige3 rjpaige3 is offline
Default Fuel pump bolts 1978
So... while diagnosing my fuel delivery issue, I've found that the fuel pump bolts are in fact missing. What size and length are appropriate for a '78 400 engine?
Old 05-27-2019, 02:12 PM
78w72 78w72 is offline
missing- as in not there while the pump was hooked up & running?
Old 05-27-2019, 02:45 PM
As in not there after failure, pump is currently sitting in place supported by the carb feed hard line. Engine was running fine before then.
Old 05-27-2019, 02:57 PM
fuel pump bolts should be a 5/16 coarse thread... about 1"-1.25" long.
Old 05-27-2019, 03:26 PM
Scott Thelander's Avatar
that might fix the oil leak too....?
Old 05-27-2019, 04:05 PM
Cool, thanks.
Old 05-27-2019, 04:27 PM
damm
I hope the threads arent hammmered in the timing cover ...
Old 05-28-2019, 12:23 AM
Well, got some new bolts, a gasket and some loctite, seems to be okay for now.
Old 05-28-2019, 07:35 AM
steve25 steve25 is offline
That pump not being bolted down would have me wanting to confirm that both the pump arm and the eccentric was not beat up / chewed up and ready to fail or the arm was not chewing up the face of the timing chain and was ready to fail and all the while either of these two dumping metal into the motor!
Old 05-28-2019, 07:49 AM
1969GiPper 1969GiPper is offline
X2
Unless I’m incorrect to inspect the eccentric you’ll have to pull the timing chain cover off. That gives you a chance to inspect/replace the timing chain/cam gear.
Old 05-28-2019, 08:33 AM
Well with a mechanic's mirror you can likely confirm things are ok by backing the pump off and peering in with the aid of a small light while a buddy cranks the motor over with the spark killed.
Old 05-28-2019, 11:17 AM
Pump arm didn't contact anything in there, no signs of wear or rubbing other than the eccentric landing; pretty sure I would have heard that in the couple minutes after the bolts walked out while I was still rolling on the remainder of the float bowl. It looks like the 3 fuel lines kept everything lined up perfectly just below the cam eccentric. I'm just going to have to keep an eye on those bolts and maybe start thinking of doing the in tank pump/TBI conversion sooner rather than later.
