Old 07-02-2019, 06:11 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
Default 1st time assembling an IA II short block
Not sure why nothing attached to the last post. I'll try again.
Assembling a friends 535. I cleaned the block today and while going through the bolts and parts he brought to me I found these plugs. I have heard there are some screw in plugs that must be installed behind the bellhousing but I dont see where they go. The freeze plugs and screw in plugs are already installed there. The Bloch is supposed to be ready to assemble. Be picked it up from a machine shop because they had it for a very long time and were not working on it. ..any way..where do these go?
Old 07-02-2019, 06:16 PM
73 TRANSAM 73 TRANSAM is offline
Those looks like the screw in freeze plugs that go in the sides of the block. 3 on each side of the block. Also that is the option screw it plugs but it normally comes with a brass plugs that looks like it belongs to a plumbing section.
Old 07-02-2019, 06:37 PM
They are 1/2" pipe size with an o-ring to seal them. ..the freeze plugs are another thing that threw me off. They look to be press in plugs not screw in.
Old 07-02-2019, 06:41 PM
slowbird's Avatar
slowbird slowbird is offline
KRE blocks have press in freeze plugs, IA blocks are screw in. Maybe its a KRE block?
Old 07-02-2019, 06:51 PM
I'll look for more details.
Old 07-02-2019, 07:22 PM
The only definitive marking on the outside of the block is this "stamped" Indian Head.
ID:	515225   Click image for larger version
ID:	515226   Click image for larger version
Old 07-02-2019, 07:35 PM
hp 400 dave's Avatar
hp 400 dave hp 400 dave is offline
Looks like a IA 1, not a 2. The 1 had press in freeze plugs, at least my tall deck did. I don't remember where those plugs went.
Old 07-02-2019, 07:52 PM
I didnt know that. It may be an IA 1. My IA block says. ... IA XX. On the distributor pad area. This block doesnt.
Old 07-02-2019, 07:59 PM
Never had an AI 1 block.
But I'd look where most sizes of that type go?
Oil galley plugs, one for oil hole by the distributor.
(the one behind a freeze plug on rear of block is usually forgotten?)
Old 07-02-2019, 08:34 PM
77 TRASHCAN's Avatar
That's what I was thinking, the pass side internal plug that seals the oil galley, but then, why are there so many of them???
Shut it off
Shut it off
Old 07-02-2019, 08:47 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's an Indian Adventures (IA1) block you are describing.
Go fast, see Elvis!
Old 07-02-2019, 09:15 PM
I was thinking one in rear, 2 under cam timing gear (usually press in on stock block) one for the hole by distributor.
Old 07-02-2019, 10:47 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
Those may not be for the block they look like the plugs for a custom aluminum oil pan to access the bolts or studs inside pan
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 07-03-2019, 06:47 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
look like hydraulic plugs to me. Could be what richie says, I have a pan like that and it was reg pipe thread/plugs.
Should be a good block, i had no problems with mine. What is bore size? Make sure you check the hole where the clutch rod would thread into. I have heard they can be thin there and leak. Mine did not, but thought i would mention it. Also, anything above 4.375 bore, you should have it sonic checked,as there is some casting shift around the 6/8 5/7 cylinders, that may require a sleave at bores above 4.38
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-03-2019, 06:53 AM
Thanks for the help. I guess they could be from something other than this block. The owner just brought me everything he got from the previous owner/machine shop.
Old 07-03-2019, 05:52 PM
aaronman aaronman is online now
Agree with Richie. Those look exactly like the plugs that are used to access my Moroso custom oil pan bolts.
Old 07-11-2019, 07:13 PM
AG's Avatar
AG AG is offline
God bless Dick Duclow.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 07-11-2019, 07:25 PM
mgarblik mgarblik is offline
X2 for Mr. Duclow and Tom as well. The tradition has been carried on well by Frank and Bob, All Pontiac. As far as the plugs, I have built 3-4 IA I's and none of them had any plugs with O-rings. All the plugs were pipe thread.
Old 09-08-2019, 08:41 PM
Finally got the pistons/rods in. Have to throw out a big thanks to Scotty G @ Scotty's Race Engines in Spring Hill, Fl.
Checked deck height, got the cam degree'd in today, rings filed to fit and assembled. After I took the pics I put the oil pump and windage tray on. Next up is just to fit the oil pan, and timing cover.
ID:	519734   Click image for larger version
Old 09-09-2019, 03:13 AM
Dragncar Dragncar is offline
Looking good Scott. What kind of rods are those ?
Thread Tools
Display Modes
