Old 07-10-2019, 01:10 PM
pfilean's Avatar
pfilean pfilean is offline
Default VinAir in a 61 Pt 4
The heater valve is often mounted in the inlet line somewhere but I wanted to get it a little more out of sight. I know Jeff Walker mounted one above the manifold but I like the big air cleaner and I thought that space was probably to limited. So I made a bracket and mounted it within the original engine side air duct. I hope I never have to get it out as that cold be a problem. I also had to make my own heater outlet tube. I tried to use pieces from VA but t was just to tight.
ID:	515593   Click image for larger version
ID:	515594   Click image for larger version
