Old 07-23-2019, 09:55 PM
eric65's Avatar
eric65 eric65 is offline
Unhappy Finally test drive
Well after 7 year resto finally got this out more than "just outta da garage"
test drive went ok need some insurance and a license
A bunch of small detail stuff to do but is looking ok for a "DIY resto"
Am not happy with color mis-match on trunk to quarter top. Was 2 mixes of the Baja Gold and dont think the 2nd batch hit the mark. I may need a re-do over the trunk and other 1/4.. Which would require a 3rd mix
Paint is Moto-Base by Chads Is nice stuff to work with.
Used SPI Clear and epoxy Great paint by Barry and cudos for Barry and his tech help for hillbilly painters like me
Weird thing is you cant tell from fender to door . .. The drivers fender is the 2nd batch and cant really see diff in door So is pass door to pass fender
I guess the way the sun hits it makes the difference.
Old 07-23-2019, 10:23 PM
Golds and silvers are a bitch.
Old 07-24-2019, 05:16 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Congrats! Looks pretty good from here!
Mitch Kunath
Old 08-01-2019, 05:21 PM
John Milner's Avatar
John Milner John Milner is offline
Looks great. If it were me, I would not sweat the color match. It certainly isn't really noticeable from the pictures.
Old 08-02-2019, 07:42 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Car looks great, drive and enjoy!
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 08-02-2019, 08:40 AM
indymanjoe's Avatar
Looks great! Enjoy
Old 08-02-2019, 10:34 AM
Tell those who ask, it was mis-matched like that when you bought it new off the lot - and got a discount. Then faithfully replicated the variation during the restoration.
Great accomplishment and hope you get to enjoy it often.
Are the top and interior both sandalwood ?
Or is the top -white ?
On a 3rd mix - best bet would be to recolor trunklid and blend color onto top of BOTH quarters. Then clear all panels. Step the clear out on the quarters with each coat of clear, so that there is only 1 coat of 'new' clear where quarters meet doors.
More than 1 coat will start noticeably darkening the color match you might have now at those panels.
VERY lucky that any of it matches each other. imho
Old 08-02-2019, 10:40 AM
oh yeh , if you go for mix #3 - do a spray out test-sample first.
Verify it will be a blendable match somewhere in the range of the 2 colors you have now.
Could make life easier, and less expensive.
If you go for mix #3 - HOPEFULLY the clear you are using is actually 'clear' . Not a 'yellow cast' clear.
Old 08-03-2019, 10:01 AM
antique69lemans antique69lemans is offline
I'm not a painter, but did you spray those panels hanging in the position they would be on the car ? It is possible the color is a match but the paint laid out in a different direction is what you see from lighting.
Old 08-03-2019, 10:07 PM
eric65's Avatar
thanks for support
Ya color is 10|55 (GC on PHS) and interior 257 sandalwood .. Had the dark dash/column and vent covers
Clear is SPI 4000 universal.
anyone hear of tinting clears to cover? Just asking
ya true antique allsprayed in position as laid. I had stripes in the pass door so ran out of paint to re-cover the tiger stripes.
I'm sure its due to the re-mix all were sprayed in approx same temp and humidity. With same gun
I found as many boards say the Iwata lph400 isnt great for base. Although BarryK said I had my gun pressure too low as I did manufacture recommendation. He indicated they say that to get the gun in VOC specs Iwata recommended 16psi inlet which is too low.. On the re-spray I went with the same pressure as Chads said if I changed gun pressure the color would change as well
Old 08-08-2019, 02:52 PM
kylek350's Avatar
kylek350 kylek350 is offline
Send a message via AIM to kylek350
Wow, great looking car! Congrats!
Kyle Kruszewski
  • 1970 Tempest Post Coupe - Baja Gold, Green interior, 350/TH350 - (1?)32k miles, original condition barring repaint
  • 1970 GTO - Granada Gold, Sandalwood, factory 455/M-21 - Awaiting restoration
  • 1951 Chieftain Deluxe Eight 4-Door Sedan - Saturn Gold, Hydra-Matic - Hibernating since 1969
Old 08-09-2019, 02:02 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Wow! A true two tone GTO, not a vinyl. Luv it! Quite unusual to see these days. Looks fantastic!
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
