Old 08-05-2019, 02:29 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Default Need help with top of cowl detail
We are almost ready to paint my Norwood built '74 T/A. Car is Admiralty blue with the blue interior. Of all the pics I took while disassembling, I didn't take any of the top of the cowl showing paint detail there. I know the dash blue comes down a ways on top of the cowl, but how far? Also, would the blue from the dash be covering black from the firewall or the red/brown primer? Pics please if you have any!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 08-06-2019, 04:30 AM
Aus78Formula Aus78Formula is offline
Simply overspray from dash coverage and would differ from car to car and painter. It didn't get as far as the firewall unless the painter had a fit.
Old 08-06-2019, 09:16 AM
TAKerry TAKerry is offline
It doesnt go onto the top of the cowell too far. It should stop at the bottom of the windshield, however they were not taped off at this point, so there will be overspray. Im sure the guys who did this could do it blindfolded and knew exactly where to hit the seam when spraying this area.
Old 08-06-2019, 04:11 PM
3tas4me's Avatar
Thanks for the replies, but what color would the blue dash paint be covering? The red/brown primer or black?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 08-06-2019, 04:34 PM
The top of the cowell should be a satin black. The entire car body would have been dipped in primer, I assume for 74 it would be red oxide, which to some looks like a brownish colour. The top of the cowell as well as the firewall would have been painted satin black, along with the rest of the engine compartment. The black paint should be sprayed to the bottom of the firewall overlaying the primer. There is no direct line separating the two. Black is oversprayed onto the primer bottom (which should be left in red oxide). Then the metal dash gets painted with the same overlaying technique at the top of the cowell. My 77 is black and it really didn't make much difference at that junction because it was the same colour. On my 79 which is silver, I masked off the dash at the bottom of the windshield line before I painted the cowell top. May not be 'factory correct' but I think it looks a bit neater.
Old 08-07-2019, 01:09 PM
3tas4me's Avatar
Thank you!
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 08-09-2019, 11:47 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Cowl paint
Just happen to have the hood off my 74 with 73,552 miles on it. Admiralty Blue, light blue interior.
ID:	517374   Click image for larger version
ID:	517375   Click image for larger version
Old 08-11-2019, 09:20 PM
3tas4me's Avatar
Any blue on the top of the cowl outside the windshield?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 08-11-2019, 09:45 PM
Yes the blue goes to about where the hood seal is, more blue in the center than the outsides. Hard to see in pics. Ever been to Fargo ND? You can come see in person if you like.
ID:	517505   Click image for larger version
ID:	517506   Click image for larger version
Old 08-11-2019, 10:03 PM
It's basically overspray from the dash area for where the glass sits, some have far more than others.
Old 08-12-2019, 04:31 PM
3tas4me's Avatar
I wish I had taken a couple of pictures of mine before they primed it. Impossible to tell now.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 08-13-2019, 09:15 AM
x2, what he said.
Old 08-13-2019, 09:16 AM
We all know, they weren't building show cars. Other than the buyer looking under the hood, the only other person to see underneath was the guy doing oil changes. Factory/corporate could care less what it looked like.
