Old 08-05-2019, 10:33 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default 303 Pontiac Engine at Norwalk
This was by far the neatest thing I saw in the swap meet area. What a piece of history.
ID:	517157   Click image for larger version
ID:	517158   Click image for larger version
ID:	517159   Click image for larger version
ID:	517160   Click image for larger version
Old 08-05-2019, 10:40 PM
400 4spd.'s Avatar
Very unique. Thanks for the pictures.
Old 08-05-2019, 10:47 PM
Stuart's Avatar
Stuart Stuart is offline
I wouldn't be surprised if Tom S. knows something about that particular engine.
Old 08-05-2019, 11:18 PM
tom s tom s is offline
Said to come from Buck Baker.Incorrect carb and balancer,pretty much everything else looked good.I have owned 2 of them that I did strokers too.One was 366 which a board member owns now and the othe 390 CI which was in my 69 TA that sold at Mecum last Saturday.Would like to have it was just not worth the 25K to me with out the carb and balancer.Tom
Old 08-06-2019, 12:17 AM
dataway's Avatar
dataway dataway is offline
Cool that they consider those stamped steel rockers good enough for an engine like that.
Old 08-06-2019, 09:47 AM
cdnroundport cdnroundport is offline
Tom is that throttle bracket specific for A or F body?
Old 08-06-2019, 10:00 AM
Tom Vaught's Avatar
Boost Engineer
Tom, did they modify the RA-V intake to allow installing the 3-Barrel 950 cfm carb in the intake?
Tom V.
Old 08-06-2019, 10:16 AM
Dick Boneske's Avatar
As a bonus, Dimitri Toth was at Norwalk to detail the machining & history of this engine. He still works at GM in their engine development area. The original engineering drawings called this a 302, but Chevrolet didn't like Ponitac having the same designation as their own 302, so management forced the change to 303.
It's interesting to note that the later 301 Pontiac engine used the same 1/2" lower deck height as the 303. Too bad they didn't stick with the stout bottom end of the 303.
Priceless piece of history for Pontiac lovers, but $25K was a little high.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-06-2019, 10:30 AM
Tom,I did not pull the carb but I would assume so.Tom
Old 08-06-2019, 10:32 AM
The bracket was for either the birds or A bodies.The mount on the intake was setup to work with that bracket.Chuck Henley repoped the unique brackets.Tom
Old 08-06-2019, 11:40 AM
unruhjonny's Avatar
very cool!
I really like how 'Tom S' actually runs these engines... where as it seems that most others use them a paperweights.
1970 Formula 400
Old 08-06-2019, 11:44 AM
I bought a set of 303 heads,a intake and carb at Norwalk.I have a std deck 303 block being built as a 428 right now,hope to have it on the dyno the end of the month.I have a ready to build 301 turbo block here that I might put the 303 heads on it with a factory X ram 2-4 intake.Thats in the future maybe.Tom
Old 08-06-2019, 11:49 AM
Originally Posted by unruhjonny View Post
very cool!
x2
Right up there with people who put muscle cars in their living room.
Old 08-06-2019, 12:01 PM
unruhjonny's Avatar
Originally Posted by Chief of the 60's View Post
x2
I think those are called "man caves" now... from the outside they look like a garage, but the inside paints a different picture.
I have done design work for many houses like this.
1970 Formula 400
Old 08-06-2019, 01:05 PM
bird72's Avatar
bird72 bird72 is offline
Seeing those spread out ports on a Poncho sure gets ones attention!
X3 on Tom S at the forefront of continued exotica testing in the real world. But I bet he has a cool paperweight too, ha...………..
72 Bird
Old 08-06-2019, 01:11 PM
LOL,I really dont.My problem is im not a collector.I build stuff and when im tired of it I move it on to someone else to enjoy.I have lost count on how many V engines I have built,think it around 7-8.I said the 366 NASCAR was my last but got sucked back in and had to go out in the market and buy stuff to put another together.My issue now is balancers,no clue where to find one after this current engine.Tom
Old 08-06-2019, 01:20 PM
grandam1979 grandam1979 is offline
They had a picture of the car it came out of next to the engine but I didn’t get a picture of it.
Old 08-06-2019, 01:48 PM
george kujanski's Avatar
To those of us who have no clue...myself included.....what's a 303 engine?
George
Old 08-06-2019, 02:03 PM
Actually, I have seen pictures of a Boss 9 in one guy's house and a Hemi Cuda Convertible in another guy's house. What a freaking shame.
Old 08-06-2019, 02:04 PM
unruhjonny's Avatar
George
/\ RAV engine, short deck, to reduce displacement and make it eligible for SCCA 'Trans AM' racing series which had a 5.0L displacement limit.
IIRC it was initially intended to be a production engine of sorts to make using it legal, but the SCCA adjusted their rules so that Trans Am's could be built with larger engines and still be eligible for the series.
1970 Formula 400
