Old 08-13-2019, 03:17 PM
robscar's Avatar
robscar robscar is offline
Default OHC6 parts
I have many parts to part ways with.
2 timing covers. 1 aluminum, 1 plastic, 30.00 obo each + shipping
1 Engine oil pan 20.00 obo + shipping
3 sets of lifters (?) 30.00 per set + shipping
3 set of rocker arms(?) 30.00 obo per set + shipping
1 E cam 50.00 + shipping
1 C cam 25.00 + shipping
2 timing belts 15.00 ea + shipping
2 cam gears 30.00 ea + shipping
1 crankshaft gear 15.00 + shipping
Working 1 bbl carburetor with linkage, fuel line, and air cleaner for 67 Firebird.
50.00 + shipping
1 Rebuildable fuel pump 30.00 + shipping
1 67 1bbl cylinder head 30.00 + shipping
1 67 4bbl cylinder head 50.00 + shipping
3 camshaft housings 25.00 ea + shipping
1 67 engine harness. Brand new. For Firebird with auto trans Part # 11205 in Ames catalog. 80.00 obo + shipping
2 distributors. Both have caps, rotors, and wires. 1 clean, 1 dirty. 50.00 obo + shipping for clean unit. 30.00 + shipping for dirty unit.
1 new unused water pump with cast impellor. 75.00 + shipping
1 Auto trans flywheel. Ok usable condition 10.00 + shipping
3 oil fill tubes. 5.00 ea + shipping
1 Alternator/ps bracket 50.00 + shipping
1 Thermostat housing and bypass 15.00 + shipping
1 manual shift cross bar with one adjustment rod. 30.00 + shipping
1 3 spd Hurst shifter (no shift handle) with one linkage rod 30.00 + shipping
1 throw out arm. Nice condition 20.00 + shipping
ID:	517665   Click image for larger version
ID:	517666   Click image for larger version
ID:	517667   Click image for larger version
ID:	517668   Click image for larger version
Old 08-13-2019, 03:23 PM
robscar's Avatar
more pictures
ID:	517670   Click image for larger version
ID:	517671   Click image for larger version
ID:	517672   Click image for larger version
ID:	517673   Click image for larger version
Old 08-13-2019, 03:28 PM
robscar's Avatar
More pictures
ID:	517675   Click image for larger version
ID:	517676   Click image for larger version
ID:	517677   Click image for larger version
ID:	517678   Click image for larger version
Old 08-13-2019, 03:37 PM
robscar's Avatar
More pictures
ID:	517685   Click image for larger version
ID:	517686   Click image for larger version
ID:	517687   Click image for larger version
ID:	517688   Click image for larger version
Old 08-13-2019, 04:09 PM
robscar's Avatar
What's that you say, more pictures.
Some things I did not list previously.
Firebird OHC6 frame and engine mounts. One frame mount had to be cut off the frame, so the hole has a notch. Does not affect bolt clamping ability. Engine mounts are a bit dry rotty, but still usable. 50.00 + shipping
This is a kit for installing a 200r4 trans with a OHC6. Has a cable and misc brackets for hooking things up. 75.00 obo + shipping
Poly auto trans mount 5.00 + shipping
I will be listing additional things. I am located in south central Pa.
ID:	517697   Click image for larger version
ID:	517698   Click image for larger version
ID:	517699   Click image for larger version
ID:	517700   Click image for larger version
Old 08-15-2019, 03:09 PM
wayne228's Avatar
wayne228 wayne228 is offline
Would you happen to have a 4 bbl air cleaner ? What condition is the 4 bbl head in ? Also interested in the 1 bbl carb.
Old 08-15-2019, 07:59 PM
robscar's Avatar
Sorry, I do not have a 4bbl air cleaner. The head is greasy. I will get some more pictures tomorrow. I still have the 1 bbl carb. The story on the carb is that I ordered one through Rock Auto, installed it. It worked for about 20 minutes, then the accel pump stopped working. Returned it and the replacement did the same thing. So, I took the base from the rebuilt unit (which was the real problem on my original carb) and put the body from my old unit and came up with a good working unit. So if you are interested in the carb, for the shipping price of the working unit, I will send the core, and any gaskets I have left over from working on my original carb.
Old 08-16-2019, 05:13 AM
robscar's Avatar
If anyone is going to the East Coast Regionals, I will be there as a volunteer. If you are interested in anything, you will be able to find me (Orange shirt, Rob) and I do not live far so you could see any of the items listed.
Old 08-16-2019, 10:02 AM
wayne228's Avatar
Have fun at the Regionals . I'll take the carb. After the event let me know how you would like payment by PM. I will take the carb for sure & let you know on the head after you have time to post the pictures.
Old 08-16-2019, 05:15 PM
robscar's Avatar
I sent you a pm.
Old 08-19-2019, 08:40 PM
sprinter 2 sprinter 2 is offline
PM sent
Old 08-20-2019, 07:51 AM
robscar's Avatar
The aluminum timing cover is gone.
The 1 bbl carb is also gone.
Old 08-21-2019, 06:53 PM
robscar's Avatar
A few pics of the heads
ID:	518364   Click image for larger version
ID:	518365   Click image for larger version
ID:	518366   Click image for larger version
Old 08-21-2019, 06:56 PM
robscar's Avatar
second head
ID:	518368   Click image for larger version
ID:	518369   Click image for larger version
ID:	518370   Click image for larger version
Old 08-21-2019, 07:04 PM
robscar's Avatar
The head with valves weighs in a 76.6lbs. Figure 80 with packaging. My zip is 17022 if you want to calculate shipping.
Old 05-03-2022, 09:36 PM
BLACK 67 GOAT's Avatar
BLACK 67 GOAT BLACK 67 GOAT is offline
Do you still have the thermostat housing with bypass by any chance?
