Old 09-23-2019, 10:26 PM
Red Box Rebel Red Box Rebel is offline
Cool Anyone Remember Rubber Trunk Mats? '68 GTO
When I bought my first GTO in 1974 it was a '68 GTO and it came with a real rubber trunk mat with a black & White hounds tooth pattern.
I am wondering why I cannot find a new rubber trunk mat. With all the GTOs and other Pontiac family A-Bodies and F-Bodies out there, you would think SOMEONE would reproduce the RUBBER trunk mat.
So, everyone needs to call the major parts houses that sell A-Body parts and ask them to find a supplier for real rubber hounds tooth trunk mats.
Rubber is just nicer than vinyl. If someone still makes them, please let me know.
Thank you
Old 09-26-2019, 07:45 PM
JimFB400HO JimFB400HO is offline
Have you looked at the NPD mats?
C-TMR-415AA Trunk Mat Rubber Aqua And Black Houndstooth 1-Piece
and
C-TMR-415AG Trunk Mat Rubber Gray And Black Houndstooth 1-Piece
Old 09-28-2019, 09:29 AM
dhutton dhutton is offline
Great way to rust out your trunk floor trapping moisture. Trunk mats are a bad idea imho.
Don
Old 10-02-2019, 08:38 PM
bkmont's Avatar
bkmont bkmont is offline
Have you tried these guys?
https://www.ebay.com/itm/1968-Pontia...AAAOxyW7tRh09b
The Following User Says Thank You to bkmont For This Useful Post:
Old 10-27-2019, 09:07 PM
Originally Posted by bkmont View Post
Thanks. I will check it out!
Old 10-27-2019, 09:08 PM
Don
Sorry, but I respectfully disagree. If you have water getting into your trunk, you have bigger problems than having a rubber trunk mat.
Old 10-28-2019, 08:46 AM
I was referring to condensation. Constant cycles of heating and cooling will cause moisture to accumulate under the mat. It has nothing to do with leaks....
Don
Old 10-28-2019, 12:31 PM
unruhjonny's Avatar
Many years ago, I found a nearly mint rubber trunk mat in a 1970 full sized (Canadian) Pontiac;
I bought it, and cut it to match the stencil of a 1973 Firebird trunk mat.
I recently threw most of it out because it had fallen apart... I kept a bigger chunk of it though to compare against my intended eventual replacement mat.
1970 Formula 400
Carousel Red on black (std) interior
1:286 W66/L78/M13 or 1:301 W66/M13
(likely one of very few '70 M13 Formulas still existing)
Luke 23: 39-43 / Ephesians 2: 8-9 / 1 Corinthians 2:12-14 / 2 Timothy 3:1-5;12
Old 11-01-2019, 07:33 AM
chuckies76ta's Avatar
You really need to listen to Don. He's right about rubber mats causing rust on the trunk floor. The rubber doesn't breathe.
I've seen it first hand. Causes tiny rust pin holes. Whole trunk floor had to be replaced.
Old 11-01-2019, 04:53 PM
Cool Dry, no Olives and certainly not stirred or shaken!
I do not doubt that he is correct, but I like the rubber over the vinyl and can keep the trunk floor in rust free condition with the proper coatings. Where I live in Texas is a dry enough climate that we do not have the rust and humidity problems they have in Houston and the Eastern part of the USA.
Old 11-23-2019, 12:02 AM
1965gp 1965gp is offline
Your not BS’ing about the humidity in Houston. There are days I can go in the garage and the entire floor is wet. This is with an epoxy coating so I think the condensation just lays on top rather than soaking into the concrete
Old 11-24-2019, 10:27 PM
I put the trunk at in my 72 Firebird that I bought from Ames and was surprised that it had a jute backing? I would think that would retain water and cause rust problems later on? Is that what was originally offered?
Old 11-25-2019, 01:48 PM
unruhjonny's Avatar
wow!?
I thought that the trunk mats were the same through to 1972;
I have only two good points of reference;
1) three owner, single repaint only, but otherwise completely original 1971 Trans Am
2) a painfully original 1970 full sized Pontiac that I removed the trunk mat from
both were a thin but heavy, rubber mat with no backing.
The second example, I actually bought, and used a 1973 Firebird trunk mat as a pattern to re-cut an place in my car.
I know that by 1973 the trunk mat should have been a jute material, at least it was that way on Firebirds.
A couple years later the material changed again to a thinner rubber skin backed black "carpet" trunk mat (I always liked these ones).
1970 Formula 400
Old 11-25-2019, 10:30 PM
I mean it looks nice and honestly the only water the car will see is from washing so it should be fine. I was just surprised that was a factory option
Thread Tools
Display Modes
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
