need 3.5" muffler recomendation
I have been running Dyno max ultra flows full case mufflers for the last few years. I bought the stainless steel ones thinking they would last for a long time. The dam inner perforated tube is regular steel. Guess what rusted out and tried to make it's way out of the muffler along with fiberglass.
My 10.0 index class requires mufflers so have to get new ones. Anyone know of ones that are stainless steel throughout? I was looking at Magna Flow"s. |
I'm pleased with the Pypes Race Pro 3.5" on mine. I cannot say if they are stainless throughout.
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
Pypes 3.5 race flow
I as well have the race flow & actually really like the sound
1970 GTO Judge. New times 10.60/126 with a 1.45 60ft. 2002 FIREHAWK-conv. 6-sd. 1969 Carousel red Judge Ram Air IV 722 heads. 4-sd. Black interior. |
I was told the Pypes Race Flow had the quietest sound...
Here's a video of mine. basically 4 ft. of 3 1/2" straight pipe, 3 1/2" Race Pro mufflers and turn down/outs. You should be able to pick the sound of my car out from the other car.
https://youtu.be/VK8C7I4yMnA
I love the spin tech rumble
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Do the Pypes race flow mufflers choke down inside? I want to make sure they are a full 3.5 inside.. If they do I might try them this time.
I'm pretty sure they are the same size inside as the 3 1/2" pipe. If they weren't, I would have made a mental note about the reduction. My car is about .08 quicker when I take the mufflers off which is probably only 20 lbs weight so they do cost me a few HP.
I have 3 1/2" Borla's as far as i know there stainless all the way through. Been on my car since 2006. No rust on them..
https://www.summitracing.com/parts/bor-40946/overview/
My Half AN Injun..... |
The single FlowMaster 40-series on the Bandit is the same one Wangers put on it at least 13 years ago- not stainless, but long lasting. It's 3.5" in and 3.0" out.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
After 2 sets of Flowmaster rusting, I went with Borla's more than 15 years ago
I’m a Spin Tech as well. Sounds like a 60 Indy Car
Spintech x 3
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
We have the Magnaflows on Jakes car. 3.5” in/out. Forgot the number. They are very short. We have an X pipe also. Sounds great. Haven’t had any issues rusting out. Been on the car since 2014.
Brian
Boobs & bacon |
I have 3" Flowmaster 50 series. They are very long and took some work to make fit. I have the Aluminized version not stainless. But they are 11 years old and in great shape with no rust. Love the sound of Flowmasters.
https://youtu.be/8QMmYxJy0hQ. Link to my Firebird in the burn out
For performance i would never choose a chamber type muffler (spin tech & Flowmaster), a straight through design is better for performance. I ran the Pypes race mufflers and ran 9.0s, i tried with and without the exhause and even though the car was 50lbs lighter without the exhaust it ran almost the same et/mph. I don't know how long they'll last but performance wise they were great.
