Old 12-08-2019, 08:21 PM
gogtogo's Avatar
gogtogo gogtogo is offline
Default Victor Intake
Looking for helpful tips on the pro’s and con’s of the clover leaf cast into the Victor 4500 Intake. I’m on the fence of having it removed as I’m considering a Pro Systems SV-1 carb. The clover also tends to limit the use of tapered spacers as well.
Old 12-08-2019, 08:32 PM
slowbird's Avatar
slowbird slowbird is offline
Tapered spacers won't matter if you run a SV-1 carb
Old 12-08-2019, 09:12 PM
gogtogo's Avatar
Agreed, I just see more con’s than pro’s with the clover leaf. What is the benefit, as I’m sure it adds $$ to the casting process.
Old 12-08-2019, 10:54 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The clover leaf can help and hurt it depends on the application. If your engine needs more plenum volume and you can't get it somewhere else... Remove the cloverleaf.
Go fast, see Elvis!
Old 12-09-2019, 12:28 AM
Mark G Mark G is offline
I had a few Victor professionally ported over the years all had the clover leaf removed.. my current combo I used a Northwind made better power ..
Old 12-09-2019, 07:39 AM
steve25 steve25 is online now
Without knowing how many cid your motor is , what heads your running , there ball park runner volume and what they flow, or to be more accurate how much of there flow potential you are making use of with your Cam lift and how high your spinning the motor to, then the your question your asking really can not be answered here!
Some things that you can count on is that both the NW and the Victor can use more Plenum volume with cams above 270 duration @.050" so even just a 1" spacer helps out a good amount with dampening reversion pluses and allowing air flow to take a bigger less restrictive arc into the top of each runner from the Plenum.
The longer runner of the Victor will produce more midrange torque then the NW so which Manifold may work best comes down to where the rest of the motor combo is built to make its Torque and hP peak .
Old 12-09-2019, 02:58 PM
The Victor did not produce more midrange torque than the NW in my combo Also read this http://www.sdperformance.com/newsStory.php?newsID=53 I am talking from my experience NW for the win ..
Old 12-09-2019, 03:02 PM
Murf Murf is offline
So is your combo “secret squirrel “ stuff or what?
More info would make the info you have shared more useful.
Murf
Sent from my iPhone using Tapatalk Pro
Old 12-09-2019, 04:54 PM
Murf
505 pump gas hydraulic roller E-heads 2.28 intake 1.71 exh NW intake
750 hp N/A 11.1 compression Motor was built for nitrous Rings gap etc.. 8.91 @ 157 mph 3280 lbs on small shot wrong converter .
Old 12-09-2019, 06:19 PM
PAUL K's Avatar
At 3520 lbs. we went 5.20 @ 134 in the 1/8 with a pump gas 500ish cid engine. With and without the cloverleaf in place. On that combination it didn't make much difference. Fwiw
Go fast, see Elvis!
Old 12-09-2019, 06:44 PM
That is what I found also Paul .. Can I ask how much spray that just over 1200 hp What did it make on the motor N/A ?Also the mph that just over 1300hp
Old 12-09-2019, 06:54 PM
PAUL K's Avatar
Yes Mark....400 on a plate. The engine makes around 850 NA.
Go fast, see Elvis!
Old 12-09-2019, 07:25 PM
Thanks for the reply! I didn’t realize you were talking over 500 cubes. Did you run spacers on either intake?
Murf
Old 12-09-2019, 07:37 PM
Murf
Yes a super sucker 4 hole plate
Old 12-09-2019, 07:41 PM
850hp on pump gas that is bad ass E-heads solid roller ?? I need extra 100 hp if not I am going twin turbo next year if the nitrous can't get it done . 7.90 is the goal ..
Old 12-10-2019, 09:18 AM
PAUL K's Avatar
Yes....solid roller, standard pushrod location. You can get the job done with nitrous....you just need a track closer to home.
Go fast, see Elvis!
Old 12-10-2019, 10:50 AM
We need to talk ..lol
Old 12-10-2019, 08:00 PM
BADDTA's Avatar
BADDTA BADDTA is offline
On a Monte plate?? Lol
Brian
Boobs & bacon
Old 12-10-2019, 08:25 PM
PAUL K's Avatar
Here's a 5.24 pass
https://m.facebook.com/story.php?sto...32994593525317
Go fast, see Elvis!
PAUL K's Avatar
Brian
MONTESMITHTTFMF!!!
Go fast, see Elvis!
