Old 02-10-2020, 05:44 PM
Farrell in Vancouver Farrell in Vancouver is offline
Default Fitting 1970 Coupe inner fender to a 70' Convertible
Has anyone on this forum solved the problem of fitting the coupe/hard top inner and outer wheel wells to the convertible body?
The fender wells on the verts are flat topped to make room for the top to fold in.
I have the outer well almost in place on the pass. side but I am hoping someone would have some tips on flattening the curve on the only pieces I can get to repair the rust out in the wells. I see the hammer an dolly at work here and possibly a pie cut or two.
Any vets in this process?
Old 02-10-2020, 05:48 PM
Scott Thelander's Avatar
theres a green convert ass end on portland craigs list
Old 02-10-2020, 08:49 PM
Thanks for the heads up Scott!
Old 02-10-2020, 08:54 PM
https://portland.craigslist.org/mlt/...072060493.html
if I can talk you out of the bracket for the boot on the rear seat frame top////// ????
and trunk lid spring rods
thanks.... Im 2 minutes off I-5 in OLYMPIA on your way home ...
Old 02-11-2020, 10:07 AM
Sorry Scott I'am in the northern version of Vancouver.
And I need those bits.
Old 02-12-2020, 09:15 PM
bkmont's Avatar
bkmont bkmont is offline
OPG is selling a repo 70 Chevelle convertible inner wheelhouse.
They look close to being the same as the GTO.
I just replaced the rusted out outer wheelhouse portion on my 68 GTO convertible using the coupe wheelhouse. I had to cut, section and weld to get it to fit around the fender lip. A pain but I got it to fit.
