Bleeding brakes
R&R'd all the brakes on the '78 TA and down to bleeding all 4.
I've ordered the "Pneumatic Brake Fluid Bleeder" from Harbor Freight. Has anyone used this? I also have a "combination valve bleeder tool" I've never used but it seems like a good idea to stop the valve from moving over. It's just a screw in pin. |
I did this on my 77, same bleeder, worked well. Had to keep an eye on the refill bottle doesn't sit well in our master. But it did the trick! Drained down the master first till it was almost empty. Then I used a clean rag to sop up the rest in the bottom of the master. Put in fresh dot 3 and proceeded to bleed away!
1969 Pontiac Firebird 400 - Candy Green 1977 Pontiac Trans Am 400 W72 - Black |
