Old 02-15-2020, 12:12 AM
mike76 mike76 is offline
Default how hot can exhaust tips get?
450-475 hp and full 3" exhaust. Just wondering if I can get away with painting them( rustoleum) as part of my scheme. Thx, Mike
Old 02-15-2020, 01:21 AM
462 with 2-1/4" exhaust melted plastic hosing used to kill moles.
Old 02-15-2020, 04:07 AM
firechicken's Avatar
firechicken firechicken is offline
Use high temp paint you won't have a problem. Think bbq but color may be a factor. Engine paint would be fine as well. Summary...use the right paint.
Old 02-15-2020, 05:48 AM
dataway's Avatar
dataway dataway is offline
I can't imagine exhaust tips would get any warmer than about 150 F. Hot enough to be uncomfortable to hold on to, but not hot enough to damage most any paint.
Old 02-15-2020, 07:45 AM
steve25 steve25 is online now
You should be fine with any type of good Enamel paint as they are tipically baked to improve the paints hardness anyway!
Old 02-16-2020, 10:51 PM
amcmike's Avatar
amcmike amcmike is offline
Can depend on how much fuel enrichment you're running. To give you some idea, OEMs will typically run <12:1 to protect the catalyst which can reach up to 900C (1652F).
Now a tailpipe is far away from where a catalyst would be, but that's still a lot of heat to cool before it exits. Normal enamel paint is good up to 200F. It'd probably be safe @ idle, but at full WOT I think you'd see higher than that. I would go with a high temp paint to be sure.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 02-17-2020, 11:55 AM
72projectbird's Avatar
Regular high heat paint will work fine. I paint headers with it, and they survive, so tails will be no problem.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-17-2020, 01:13 PM
Formulajones's Avatar
Use the POR 15 high temp paint and you'll never have to worry about it. I use this stuff on exhaust manifolds and after years of daily driving it still looks fresh.
https://www.jegs.com/i/Perma-Cool/77...IaArFJEALw_wcB
Also comes in silver and cast iron grey
Old 02-22-2020, 05:13 PM
NeighborsComplaint's Avatar
I touched up the welds on my header collectors, mufflers and exhaust tips with Rustoleum Stainless Steel Gray and it holds up fine to the heat even though it is not heat rated.
Triple Black 1971 GTO
Thread Tools
Display Modes
