Old 03-06-2020, 02:41 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Fuel line routing for Pontiac powered F-bodies?
I feel that I should know this but it's been 25+ years since I put a fuel cell in my 78 T/A.
My 81 T/A and 80 Formula were both SBC powered from the factory and the fuel lines run up the passenger side. Did the Pontiac powered cars have their fuel lines on the drivers side since that's where the pump is?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 03-06-2020, 03:36 PM
76TA462 76TA462 is offline
For my 76 TA the fuel line runs along the driver side. The vent line extends over the cross-member, then across the back of the cross-member to run down the passenger side. The charcoal cannister line also runs down the passenger side.
The Following User Says Thank You to 76TA462 For This Useful Post:
Old 03-06-2020, 03:46 PM
Johnny406's Avatar
Thank you, I figured running it on the drivers side would reduce several feet of unnecessary fuel line for a autocross application.
Old 03-06-2020, 07:22 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Yes Pontiac runs up driver's side as the pump is on that side.
I used the passenger side on the Camaro event hough it has a Pontiac motor as electric pump and Holley line is on passenger side.
Skip Fix
